FS534 Jammed stapler cartridge. FYI
  • habik
    • 2013
    Had a cartridge stuck and couldn't get it out by turning the clincher mechanism both ways. So to release it I used a piece of mylar to stick it under.
    First you pull cartridge out to the max, then slide the mylar under cca 70mm then push the cartridge with the mylar together all the way in cca 80mm then slide out as usual. See pic below
    The culprit is the feed tong that wont remain in the "No feed position"
    Byting on bits.
    Firmwares HERE
    • 22917
    Re: FS534 Jammed stapler cartridge. FYI
    I've done the same thing with my pocket scale (150mm ruler). =^..^=
