C258 SMB errors
    • 14331
    C258 SMB errors
    I installed a Bizhub C258 to print and scan. When installing print drivers it wouldn't automatically find the printer on the network. I had to go into devices and printers and install it manually on all the computers (6). Then while setting up SMB scanning I only worked on two of the computers. On the other four I get a 16711703 (failed to connect to the server) error when I use the host name, and a 16712692 (The user does not have write permission to the folder. The access is rejected) error when I use IP address. Has anyone had an issue like this. I'm guessing the print driver problem is related to firmware or version, however, I'm not sure what is going on with the scanning. Any help is appreciated. Thanks.
  • Synthohol
    Certified Konica Expert
    • 5731
    Re: C258 SMB errors
    #1 always install manually by IP don't use a samba port it's a train wreck.
    As far as smb scanning upgrade the FW to the latest. Was at a c287 this morning and smb scans didn't go through no matter what so I upgraded the FW an viola it worked right off..
    Also there is another thread here about turning off a security setting under client settings in SMB that may help too.
    Also make sure you add read write permissions for the user to the shared folder. Just using everyone will never work.
    I posted the smb setup guide here a few threads down maybe refer to that.
    Good luck.
      • 14331
      Re: C258 SMB errors
      Good luck.
      Not sure what a samba port is, but I usually install print drivers by just clicking on the extracted file and clicking "next" Works almost every time.
      I will be going back next week with firmware and go from there.
      Thanks.
      • Synthohol
        • 5731
        Re: C258 SMB errors
        windows creates its own port to print via netbios.
        manually adding the printer via TCP-IP is the best solid way to go.
          • 14331
          Re: C258 SMB errors
          I truly do know how to install print drivers. I DO install them using IP. I am not an IT professional so netbios and samba port are greek to me. You seem to be missing what the problem is.
          Normally when I install print drivers, I just click on the extracted file, the program searches the network for the printer, it finds the printer by the IP address. And then I click "Install". During this install, the program was unable to find the printer and I had to go into "Devices and printers" and use "Add a printer". I am guessing it is a firmware issue.
          • MFPTech
            • 486
            Re: C258 SMB errors
            If the search and find doesn't work when installing the print driver there are always problems. Try both CD and download the latest driver, sometimes one works and the other doesn't. You may also try a different IP for the machine. Once the driver wizard finds the machine you should be fine.
            Good luck!
            Sent from my SGH-I337M using Tapatalk
            • DigiMan
              • Jan 2013
              • 262
              Re: C258 SMB errors
              I second the FW road..also im greek and i find this post offensive! lol
              I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
              • kahodges
                • Mar 2013
                • 24
                Re: C258 SMB errors
                Always install with the IP address on a network. As far as smb (samba), you'll need to make sure the ports are open in the firewall on any workstation or server you want to scan to. Samba runs on TCP ports 137, 138, and 139 plus 445 and UDP ports 137 and 138. Go to the workstation or server running windows and create a shared folder. You want to make sure the user that you input on the copier has read and write permissions on the shared folder. You'll input the path to the shared folder, user and password on the copier to access the share.
                • kahodges
                  • Mar 2013
                  • 24
                  Re: C258 SMB errors
                  • guitar9199
                    • Sep 2016
                    • 1098
                    Re: C258 SMB errors
                    If the computer was unable to find the copier on the network, it's because the port is set for "NetBIOS over DHCP", which makes network discovery and SMB scan dicey at best!
                    This walkthrough will show you how to configure the computer's settings and make your life a lot easier!
                    Enable NetBIOS over TCP/IP with Windows
                    Good luck!
                      • 14331
                      Re: C258 SMB errors
                      I apologise, no offense was intended. I have no problems with greeks........ until now!!. LOL.
                      • AjitN
                        • Mar 2009
                        • 287
                        Re: C258 SMB errors
                        Hi All
                        If user do not have write permission, nobody can install scan to folder.
                        Really do not know if Twin also will work MOST EFFECTIVELY.
                        One need to appreciate IT department & their company's internal security measures.
                        My experience is that never cross the line drawn by IT department even if user insists some features on their own.
                        Hope this helps
                        • rrrohan
                          • Sep 2011
                          • 1977
                          Re: C258 SMB errors
                          What credentials are you using because Everyone does not mean Anyone
                          Is it on a domain, if so get IT to create a account for the copier.
                          The fact it couldnt even connect with hostname probaly means its default domain name isnt configured or DNS server address is missing.
                          Id write down its IP and then temp set to dhcp then back to static. Should auto correct dns settings
                          • emujo
                            • Jun 2009
                            • 3009
                            Re: C258 SMB errors
                            Having the same SMB issue with C458/C258. These are replacing e series that can SMB scan to a NETAPP NAS device without issue. C458/258 get either login error, or no specified folder error. From the control panel we can browse to the NAS, login with service account, but cannot see anything past the host. I have a C368 that can scan to the NAS w/o errors so started comparing settings. The C458 is at the newest firmware/function level so there are a couple of added settings we don't see on the C368, but one thing we noticed is under SMB/SMB Server settings, the addition of "SMB Security Signature" is newly added, but the culprit looks like the default setting of "SMB Authentication Protocol" This is set to 1.0 and the NAS is set for 3.0 with an option to accept 2.0. We changed the MFP side to 1.0/2.0 and are waiting on the IT staff to make the change to the NAS. I'm thinking this may be applicable for server 2012/2016 as well. Emujo
                              • 14331
                              Re: C258 SMB errors
                              Turns out it was norton's firewall blocking the SMB scanning. I just punched a hole in it for the copier and all is well in the world. Thanks for all the suggestions.
