Magicolor 2530DL Code: 14H
  • SwanyG
    • Dec 2014
    • 55
    [Error Code] Magicolor 2530DL Code: 14H
    What I've seen about this code tells me that there's not pressure from the second transfer roller (not exact quote) but I've seen no suggestions on how to resolve this issue. Is this problem from the transfer ass'y and if so, is it possible to disassemble the transfer unit and repair? If it's not in the transfer ass'y, how do I get this problem resolved?? Thoughts? The second Transfer doesn't have anything moving it to the transfer belt... it's just spring loaded. Your help will be most appreciated.
  • allan
    RTFM!!
    • 5459
    Re: Magicolor 2530DL Code: 14H
    The solenoid damper pads on these machines gets sticky if i remember correctly. Remove the damper pads and replace it with some electrical tape to make sure the metal does not touch metal.
    Whatever
