C227 Toner Issue
  • Gaffers01
    • May 2011
    • 333
    C227 Toner Issue
    I put a brand new C227 into a customers 2 days ago with all new toners (genuine)
    and i get a phone call from them to say the Yellow toner is asking to be replaced.
    I have checked through our remote management and sure enough the yellow toner went from 100% to 2% in a day,
    they have only done 520 colour prints.
    I believe these toners dont have chips on them so i presume it must be a toner add issue?
    Any ideas whould be a great help?
  • kingarthur
    • 1296
    Re: C227 Toner Issue
    There was a tech bulletin last year for C308 etc, which you needed to upgrade FW & then the following
    Procedure
    1. Call the Service Mode to the screen.
    2. Call the Enhanced Security to the screen. (Stop -> 0 (Zero) -> C (Clear)
    3. Touch [Engine FW DipSW].
    This is displayed only when Switch No. "59" is set to "01" in HEX Assignment in [Service Mode] -> [System 2] -> [Software Switch Setting].
    4. The switch highlighted corresponds to the colour to be reset is highlighted (ON state).
    31: Y 32: M 33: C 34: K
    EG, 31 and 32 are highlighted, after pressing END and powering off and on Yellow and Magenta toner level will be displayed at 100%
    (Note this does not mean there is 100% physically in the toner cartridge, however when it runs out of tonner the hopper will correctly detect when the toner is empty).
    MAY OR MAY NOT be the same solution.....
    • Gaffers01
      • May 2011
      • 333
      Procedure
      Great thanks i will give it a go and let you know.
      • Allister
        The Engine FW DipSW numbers are different on a C227 - 29:Y 30:M 31:C 32:K. I also updated the firmware after making this change. The existing firmware was A7970Y0-F000-G00-K7(00) when I had the issues.
        • kmfa
          Procedure
