BizHub C6500 - Carbonless Paper
  • CPM Mike
    • Nov 2015
    • 32
    [Misc] BizHub C6500 - Carbonless Paper
    From time to time, I run carbonless paper through my BizHub C6500.
    When I do this, I have a lot of issues with jamming and get the J-1706 code if running Tray 1, 2 or 3.
    In the monster paper tray 4 and 5, it just jams on the first sheet.
    I posted about the J-1706 code earlier, but, I was wondering is there are any tips or tricks to working with carbonless on these machines.
    I always appreciate you replies!!!
  • Synthohol
    Certified Konica Expert
    • 5727
    Re: BizHub C6500 - Carbonless Paper
    yes, NCR paper is not exactly certified to run at all on those however, there are these neoprene orange rollers that dont melt with the chemical on NCR paper.
    NCR has to be run from a PFC not the main body trays.
    someone here may have the part #s, ill see what i can find but those orange rollers are the only thing keeping that paper flowing.
    what PFC does the account have?
    btw, this is right from Konica...
    Related Products:bizhub PRO 1600P,bizhub PRO 2000P,bizhub PRO 2500P,bizhub PRO C5500,bizhub PRO C5501,bizhub PRO C6500,bizhub PRO C6500P,bizhub PRO C6501,bizhub PRO C6501P
    Related Options:
    Reference
    SPECIAL NOTE: Solution contribution by Gary Scimeca and Gregg Gallant, Production Print/SSD
    these are other rollers that may help...
    Reference
    The design and part number for feeding roller, paper feed roller, and the separating roller has changed since the release of the January 2007 Parts Guide Manual. The new part numbers are listed below:
    New Part Number Old Part Number ITEM
    A03X565200 55VAR75000 Feeding Roller
    A03X565300 55VAR74900 Paper Feed Roller
    A03X565400 55VAR74900 Separating Roller
    SPECIAL NOTE: Solution contribution by Jim Behrends, Production Print/SSD
    • Synthohol
      • 5727
      Konica Minolta A08R-5621-01 (A08R562101) LCT Feed Roller, Genuine (M4029)
      A08R-5621-01
      thats one of the rollers, there are obviously 2 more but i cant find the # right now.
      hope someone has the other 2 numbers.
      • CPM Mike
        • Nov 2015
        • 32
        Thank you so much for this excellent information!
        I had replaced the rollers and drive clutches in trays 1, 2 and 3 the other day and came across these orange neoprene rollers A08R562201.
        I couldn't remember why I had them or what they were for and NOW I know why I bought them thanks to you.
        Its guys like you that make this such a great forum!
        Thanks again my friend!
        • Synthohol
          • 5727
          Glad to help!!
          Just make sure your users know that the carbonless NCR paper is NOT supported and they will have to deal with occasional jams and prolly a CQ issue later on.
          Nothing to be fixed or done.
          It's like putting water in your gas tank. It's not supported but if it runs consider yourself lucky.
          Have good one!!
          • CPM Mike
            • Nov 2015
            • 32
            Originally posted by Synthohol
            Glad to help!!
            Have good one!!
            You Rock!
            • Gavin_Parkes
              We only deal with digital press and as such come across this quite a lot, I can only add to the suggestion of using the neoprene rollers.
              and if the customer is using A4 or SRA4 then set to SEF.
              As stated elsewhere unfortunately NCR is unsupported stock.
