bizhub C224 has C2152 error code
  • Samanator
    • Sep 2017
    • 571
    [Error Code] bizhub C224 has C2152 error code
    Cannot figure this out. The fuser motor turns when the machine powers up. I have checked sensor PS39 and I get a change of state when it is interrupted. I have tried another transfer unit and the code still comes up. I am not that experienced with Konicas so the book maybe saying something I do not understand. I need to get the machine working again. I would be very thankful for any help.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4511
    Re: bizhub C224 has C2152 error code
    I have never seen this code on this model. Actually last time I saw it was a C253 which had a lot of issues with this trans belt code. Since you did everything mentioned in the serv manual then only thing I can think of is re-initializing the machine?
    • Woxner
      • Jul 2011
      • 825
      check IPC3 on printer control board. if you already changed the belt .
      • allan
        RTFM!!
        • 5459
        Have seen toner cover the retraction sensor. Ended up getting a thin rubber hose to blow it out. To get to the sensor by stripping could take a hour or three.
        The issue was more common on the C360 machines.
        Have changed out control board as well but was probably an ICP.
        There is a clutch i forgot to plug one other time...
        Whatever
        • habik
          • 2013
          Pull the belt out and check if the gear to engage CMY 1st transfer is possible to turn.
          Sometimes just reseating the belt sorts this issue.
          I had it once when replacing CL8 Clutch without taking the belt out of machine. After reseating belt all went away.
          Sent from my Mi A1 using Tapatalk
          Firmwares HERE
          • Laserbeam
            • Aug 2011
            • 152
            Hello at all,
            yesterday I had the same code. Replacing with a new belt didn't succeed, after cleaning PS39 the malfunction still appeared!
            • JR2ALTA
              • Feb 2010
              • 2028
              Originally posted by Laserbeam
              Hello at all,
              Did you read the post? People pointed at ICP3 and/or controller board
              • Laserbeam
                • Aug 2011
                • 152
                yes, I have read the whole post but unfortunately I forgot to ask for the value of the ICP3.
                How many amperes or milliamperes must have a new ICP?
                • Synthohol
                  Certified Konica Expert
                  • 5733
                  none. you check for continuity. its a fuse. ohms not voltage.
                  • K-3
                    service technician
                    • Feb 2018
                    • 51
                    had something similar on a c454 and it was in the fuser drive section with the clutch cl5 that drives the transfer belt, you will have to take the assembly out and inspect for worn items. it is a pain to take out.
                    • Laserbeam
                      • Aug 2011
                      • 152
                      @ Synthohol,
                      I thougt, a ICP is the same as a normal fuse? e.g. 50V/2A
                      Could I bridge ICP3 with a small wire to test if the error C-2152 disappeares and than solder a correct ICP with the correct values?
                      • Laserbeam
                        • Aug 2011
                        • 152
                        here a picuture from ICP3
                        • Laserbeam
                          • Aug 2011
                          • 152
                          I removed the board and for a test I bridged ICP3 with a wire. After replacement the code 2152 has disappeared and the machine works fine
                          Now, I removed the wire bridge and thougt, the code would have to displayed again. Surprisingly, that was not the case
                          The machine works normaly, without any error code.
                          I can only imaging, that a connector on the board had a contact resistance and this was eliminated by removing and replacement the board.
                          Or is there any other explanation for that?
                            • 22921
                            Could you have accidentally bridged the ICP with solder while soldering? Those components are so small that a bead of solder can easily bridge the contacts. =^..^=
                            • Laserbeam
                              • Aug 2011
                              • 152
                              That's a good Idea!
                              I used a special smd-soldering iron with a very thin tip and used strong magnifying glasses.
                              I will again check the solder point closely.
