konica bizhub c654e original centering
  • Enzo
    • Jul 2009
    • 407
    Hello friends. I only had xerox photocopiers for 20 years. a few weeks ago I have a bizhub c654e machine. I have a problem. I can not find "center the page". I explain myself better. on the xerox machines I proceeded like this ... example: I have an original 10x17cm size. I imposed 10x17 as "original format" and a4 as output format. then I put "% auto" and "center page" and the photocopy came out filling the a4 sheet in a centered way. on Konica I can not find this setting. can you help me? thank you so much.
    • 22920
    Re: konica bizhub c654e original centering
    As far as I know, this is not a function available on the bizhub C654e or any bizhub I know of. =^..^=
    • Enzo
      • Jul 2009
      • 407
      I also had a machine c451 for a week and I remember it was possible to do it
      • saburnsjax
        • Apr 2011
        • 31
        Assuming you are using the Fiery print driver (since you mention it is a c654e), it will automatically do the enlargement and centering if you use these options (as example):
        Document Size: 8.5"x5.5"
        Output Paper Size: 8.5"x11"
        Layout: Scale to Fit
        In other words, make sure the "document size" is the size of the item to be printed, and "output paper size" is the physical paper size to be used... then if you click Scale to Fit it will automatically enlarge and center. I just tried it on my C654e and worked perfectly.
          • 22920
          Copying or printing? =^..^=
          • Enzo
            • Jul 2009
            • 407
            I have no problems with the print. the problem is when I make the copying.
            • saburnsjax
              • Apr 2011
              • 31
              When copying there are the Image Shift and Image Centering functions, but both of those are not 'automatic' unless you are using standard sizes (e.g., halfpage to fullpage)... when using custom sizes and enlargement you have to manually input the amount of the shift etc. definitely not as 'friendly' as the print option.
              • Enzo
                • Jul 2009
                • 407
                Hello friends. I solved my problem. the exact setting was: "image adjustment"
                • Enzo
                  • Jul 2009
                  • 407
                  unfortunately I still do not solve my problem! the solution that I had found works only when the copy is single (1-1). in double side (1-2) that option does not work!
