Ive noticed a few of the bigger 8 series machines that when you run larger jobs, like 100-200 pages jobs that eventually once the Ru warms up it starts to get some movement on the right side of the unit, then the paper starts making a different noise and soon after that it jams up in the Ru unit. I know there is a bulletin #10911 that applies to serial numbers A87JWY2105445-A87JWY2108920 but these units a well out of that range. The jam codes are 32-05, 75-42, 72-16. I placed a call with konica and they had me check all the usual suspects,which all check out fine as this is a brand new C458 and if I direct the output to tray 3 or the top of the Ru it will run till the tray is full, switch it back to the regular output tray and boom guaranteed it will jam up after the movment and paper noise starts! Anyone else notice this and when testing these please make sure you run 100-200 copies through them, Im sure customers will hate you if they have this problem and you do the basic maintenance
Ru-513
Re: Ru-513
Ive noticed a few of the bigger 8 series machines that when you run larger jobs, like 100-200 pages jobs that eventually once the Ru warms up it starts to get some movement on the right side of the unit, then the paper starts making a different noise and soon after that it jams up in the Ru unit. I know there is a bulletin #10911 that applies to serial numbers A87JWY2105445-A87JWY2108920 but these units a well out of that range. The jam codes are 32-05, 75-42, 72-16. I placed a call with konica and they had me check all the usual suspects,which all check out fine as this is a brand new C458 and if I direct the output to tray 3 or the top of the Ru it will run till the tray is full, switch it back to the regular output tray and boom guaranteed it will jam up after the movment and paper noise starts! Anyone else notice this and when testing these please make sure you run 100-200 copies through them, Im sure customers will hate you if they have this problem and you do the basic maintenanceComment
Re: Ru-513
Obvious things are hard to be understood by Japanese. They always seems to think too much, which is not bad but in many cases leads to ridiculous solutions or just too complicated.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
Re: Ru-513
I have seen the UK/European bulletin tech51 mentioned but in our case (C458 + FS-536SD) the base frame is flat so there is no need to cut any plastic.
We even replaced the the RU but the jamming still starts after about 100 pages.Comment
Re: Ru-513
Here's the info I have on it.
Follow the official bulletin and also the other document has you put a felt pad where the upper cover rests when closed. Do both. Someone told me the metal washers by the hinge was an old fix, I'm not sure if it has to be done or not. I just did one today (8 plastic washers on plate + the felt pad) so we shall see how it works.
I don't see how the washers do anything though.
11384.pdf
RU-513 Field mod.pdfComment
Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.Comment
Re: Ru-513
I have only dealt with this once, so my sample size is small, but I did not have any success with the washer mod outline in the bulletin. We received a new c458 and a new c558 with finishers/ru/etc a few weeks ago. Started getting this jam code right out of the box. After anywhere from 75-300 continuous pages, each machine would start to jam at RU513 entrance. Despite my RU's supposedly being in the "fixed" serial number range, I ordered the FOC washer kit. No improvement. Tried modifying the RU entrance so it had a wider entrance with moderate success, but still not good enough that I felt comfortable delivering to our customer. I put thousands and thousands of pages through these machines trying to get those goddamn RU513's to work reliably. In the end, I gave up. I dusted off two "old style" RU513's from my graveyard. I had ZERO problems after installing the "old" RU's, even though they were dirty and scratched up.
Rumor is that the manufacturer changed the composition of the plastic, leading to excessive warping of the entrance guides.
Somewhat related, it kinda seems like the newer 8 series runs "hot" around the fusing unit. Not sure if it is an issue with the ducting, the "quiet" fans, or just poor design, but it seems like the 8's get hotter in that area than the 4's.Comment
Re: Ru-513
[ATTACH]41051[/ATTACH]
[ATTACH]41052[/ATTACH]Comment
Re: Ru-513
We are also having the same problems as above.We noticed that when we run it from tray one in service mode its ok,but when we run it from the PC-415 it jams all the timeComment
