minolta bizhub C224e => Upgrade to C284e
  • jabatt
    • Apr 2014
    • 15
    [Misc] minolta bizhub C224e => Upgrade to C284e
    minolta bizhub C284 => to C364
    C224e => to C284e
    C284e => to C364e
    C022eDN => to C028eDN
    C028eDN => to C036eDN
    224e => to 284e
    284e => to 364e Upgrade
  • copyman
    Owner / Technician
    • Sep 2005
    • 4512
    Re: minolta bizhub C224e => Upgrade to C284e
    OK. So I guess you are saying this tool will convert the machines into the faster versions? Why? Are you planning on selling these? price?
    Haven't heard anything like this since the bizhub 250 where you could reprogram the little eprom on main board and turn it into a 350. Not sure I would want to attempt this with these newer machines. Worried enough about strange things happening with these machine don't want to add to that. I guess it would be good for those customers that say "wish their machine was faster". But I don't hear that much so not a problem.
    • rrrohan
      • Sep 2011
      • 1977
      Guess it's no worse than over clocking a PC
      • copier tech
        • 8096
        No tool required, all you need is a few firmware files & a little knowledge
        Copier Firmware - Canon Firmware, What Is Firmware, Ricoh Firmware
        • copyman
          Owner / Technician
          • Sep 2005
          • 4512
          Hey copier tech. Yeah I've heard with Kon/Min all their segment machines are same from factory. What makes their speed is basically F/W.
          Still not sure I want to attempt any changes to these newer models. Things have quieted down and I don't want to stir anything up
            • 22801
            not sure about KM... but I know when I was working on ricoh ... some of the drive parts in a slower machine weren't built to take the strain of higher speeds.. People can do as they please... but I for one would steer clear of actions like these.
            • copier tech
              • 8096
              Not really worth the effort converting a 224 - 284 all for an extra 6PPM
              • Chesterfield
                • Apr 2019
                • 4
                jabbat contact me thks
                • byronf
                  Senior Member
                  • Sep 2017
                  • 109
                  C224e => to C284e
                  C284e => to C364e
                  224e => to 284e
                  [ATTACH=CONFIG]39243[/ATTACH]
                  Hi I would love to give this a bash. how do I get one of these.
                  • emujo2
                    • Mar 2017
                    • 1580
                    In KMs the speed of the machine remains the same..for instance a C364e transfer belt rotates at the same speed as the C224e..The PPM is achieved by page timing..So a C224e will pull paper through the machine at the same speed as a C364e..There is just a larger gap in the time between sheets fed. I still think you wind up with a dead machine trying this.
                    • allan
                      RTFM!!
                      • 5459
                      Sounds scamy to start with. Does this work or just in to con you out of some money??
                      Looks like a SSD writing thing and some ISW cable. Where is the header where you plug it in?
                      Where does the ISP side got to so you need the ISP device too?
                      Would be great but i would not claim or sell the difference in obtained speed i would leave the labels on the machines as is and just score off of the reduced rotation time on the parts!
                      Yes only paper feed interval is changed between models.
                      Whatever
                      • tulintron
                        • Jul 2014
                        • 665
                        We've already switched speeds from Ricoh 907 to 1357.
                        Minolta 5500 to 6500 we can change the speed, but we can not change the serial number.
                        In both the PRO and Bizhub Office lines, in addition to firmware, you wire in different positions on the PRCB boards, which change the speed of the motors.
                        You have a card that needs to be rewritten.
                        Just firmware, will not succeed.
                        • allan
                          RTFM!!
                          • 5459
                          Wow would like if you guys can share more on this procedure. From the original post the info looks like it needs a lot of translation.
                          Whatever
                          • jotunn
                            • 591
                            Probably it works. However, there are more elegant ways to do it.
                            And... not all of those machines can be converted without trouble - some series have "universal" serial number labels, with all models mentioned on them, like this:
                            Those machines are exactly the same. The other, with model specific labels, have missing wiring, sensors and sometimes other things, so they cannot be converted easily.
                            Generally, emujo2 is right, the machines only differ in the frequency of paper picking.
                            In the past, there were more significant differences between them, for example BH423 had reflective sensors in paper path instead of mechanical, BH363 and BH423 had the same mainboard, but BH223 and BH283 had different, so the only possible (easy) conversion was BH223->BH283.
                            That's interesting
                            You cannot change S/N - maybe this is the key to convert between L and not L versions of C6000.
                            PS. I would like to contact with jabatt
                            • arahael
                              • Mar 2013
                              • 96
                              all you need is programmer, bin file from c364e to put it on 224e.. thats all from me.
                              and then change machine type ofc xD
