Bizhub C227 "Insufficient Memory" . Error.
  • stickfly
    • Jun 2010
    • 30
    Hi,
    Have a customers machine giving an error when he tries to scan a large number of pages. The error is : "The job has been deleted due to insufficient memory" displayed on the C227. The machine is only 2 months old and has only made 1500 BW prints and 150 Colour prints.
    He is scanning to 2 mac's and the error appears after the document processor has fed 50 or more pages, nothing arriving at the mac's at all. I have also tried scanning to my own mac using a crossover cable but get the same error.
    I have tried a new HDD but get the same error. ( I used the new HDD on a C227 in our showroom yesterday and managed to scan 100 plus pages to my mac with no problems ).
    The scanning properties are : 300dpi and Compact PDF but it does not matter what dpi or scan type you select.
    I have run out of ideas apart from changing the MFPB so has anyone here had this problem ?
    Also, I know that this operator is one that has messed with settings in the past few weeks, are there any settings for security etc that I should be checking that would cause the machine to do this.
    Many thanks ....... Gary
  • mo0651
    • 1054
    Re: Bizhub C227 "Insufficient Memory" . Error.
    Double check that HDD is electronically installed. Perhaps perform logical and physical format.
    • femaster
      • May 2011
      • 1458
      Only found 2 things in the un-Knowledge base on KM website. One is, make sure the HDD is set and operational, otherwise:
      Insufficient Memory message, also CE301 or CFA14 error codes.
      Problem Solution
      Related Products:bizhub MarketPlace,bizhub 227,bizhub 287,bizhub 308,bizhub 367,bizhub 368,bizhub 458,bizhub 558,bizhub 808,bizhub 958,bizhub C227,bizhub C258,bizhub C287,bizhub C308,bizhub C368,bizhub C3851FS,bizhub C458,bizhub C658
      Problem: Insufficient Memory message, also CE301 or CFA14 error codes.
      CAUSE: Problem causing CE301 by operation of screen transition of browser application. Problem with CFA14 caused by repeated operation of launching OpenAPI application / MFP standard function(copy etc) from IWS application
      SOLUTION: Some Special firmwares are available: GG1-R9 should resolve both these error codes.
      If CFA14 is not resolved then update to GG6-R9 which is available for most models in this series, should be available for the other machines by end of March 2018 .
      • copier tech
        • 8095
        Yes if the HDD is set & working then update to the latest firmware & function version.
        These 7 series have been a bit 'buggy' not as stable as previous models.
        • Bix
          • Apr 2018
          • 1421
          Hi, are you sure that by memory you mean HDD? I think he means RAM.
          I've had this problem recently with some customers. The problem happens when printing a PDF from Chrome browser. In fact if they try to print from Word / Excel the problem does not occur. Or just that first download the file and then print it.
          I advise you to turn the machine off and on again. In this way you will empty the ram
            • 29319
            Did you do a clear memory?
            Backup your address book
            • copierbarnsley
              • Jan 2017
              • 3
              Hi
              Did you find the cause of this? We are having the same issue when scanning to email on a specific user but only on certain days at certain times. We are looking more towards space in the mailbox rather than a machine issue but still not 100% sure.
              • copier tech
                • 8095
                Originally posted by copierbarnsley
                Hi
                Check in CE mode If the HDD is set & working, then update to the latest firmware & function version.
                • tsbservice
                  Field tech
                  • 7904
                  @copierbarnsley try this:
                  [Administrator Settings]> [System Settings]> [PDF Settings]> [Compact PDF Settings]>[Prioritize Quality]
                  Set Software SW No.103 0x04
                  Good luck
                  • Bix
                    • Apr 2018
                    • 1421
                    Hi
                    I had the same problem as you and I still don't know if it has been solved. Also in my case a full mailbox was suspected.
                    • mojorolla
                      The Wolf
                      • 2569
                      Solution
                      CAUSE: Insufficient scan transmission when scanning Compact PDF, Compact XPS, PPTX, DOCX and XLSX.
                      SOLUTION: To increase the scan transmission time, please make the following setting changes.
                      [CAUTION]
                      1. To set the processing method to use the CPU in the same way as without the expansion memory installed when generating a Compact PDF. (bit 2)
                      • Software SW No.103 0x00: This setting is not applied. (default)
                      • Software SW No.103 0x04: This setting is effective.
                      3. When set the Software SW No. 103 to 0x04, the scan transmission time of the following file types is increased.:
                      • Compact PDF
                      • Compact XPS
                      • PPTX
                      • DOCX
                      • XLSX
                      IMPORTANT: The effect of "Software SW No. 103 0x04" will be lost when the following is set to [Prioritize Speed].
                      Please change it to the following:
                      • copytech,mike
                        CopyTech,MIKE
                        • Jun 2014
                        • 250
                        Theres a RAM upgrade kit but thats not gonna fix anything. Check the HDD but the HDD is really only for scanning. I can also tell you guys that the C227 is a junk copier.
                        • Synthohol
                          Certified Konica Expert
                          • 5733
                          hey Mike, the thread is 4 years old.
                          doesn't mean you are incorrect, just a bit late to the party
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4511
                            I guess he thinks he is the Biz 227 expert. He got one thing right which any tech knows, the 227 series is crap.
                            • copytech,mike
                              CopyTech,MIKE
                              • Jun 2014
                              • 250
                              A full mailbox has nothing to do with the laser that is writing to the drum when its not suppose to be.
