Cygwin, writing firmware to CF card
  • kobrien
    • Oct 2008
    • 2
    Hi can anyone tell me the the best site to download cygwin and also how to use it.
    iam trying to firmware a C353 up to verJ8 firmware,
    i tryed using the imaging toolkit kit, but doesnt seem to work
    any help thanks
  • konisolver
    System Engineer
    • Oct 2007
    • 137
    Make sure you have the newer version of firmware imaging toolkit and if you do have it and it is not working--- create a temp folder on your c:\ drive.
    • dogsbody
      • Jun 2007
      • 289
      The toolkit is the way to go, wont work on vista machines yet though.
      Don't forget to enable advanced options.
      The force will be with you always.
      • DadO
        • Dec 2007
        • 401
        There is a trubleshoot file on toolkit. U have to enable CF card in windows but forgot the procedure...
        • buster68
          • Nov 2008
          • 181
          cygwin is cumbersome. Use Firmware imaging toolkit. Make sure the CF card is atleast 128mb to 256mb, and not formatted for windows. In the toolkit, when you browse for the file, select "Indexed Firmware File" in the file type.
          • kmcopier
            PSP
            • Oct 2008
            • 183
            Use latest firmware imaging toolkit, works also without problems with vista.
            • dogsbody
              • Jun 2007
              • 289
              what version are you using?
              the latest i can get here is 2.53, it wont work on any of our Vista laptops, when writing the card it comes up with an error - been ages since i tried so i can't remember the specifics but something stopped it writing to the CF card.
              Konica did give us a few things to try but none of them worked.
              Cheers.
              • kmcopier
                PSP
                • Oct 2008
                • 183
                We are using version 2.54 and works OK with vista.
                Gr KMCOPIER
                • B0265
                  • Jan 2007
                  • 718
                  The Mosel (C451/C550/C650) and Thames (C203/C253/C353) series have a "mini Cygwin" included in the Card_Work folder.
                  You can run the command directly from there.
                  • dogsbody
                    • Jun 2007
                    • 289
                    Gr KMCOPIER
                    Konica here had 2.54 on the website for a short time then took it away claiming it can corrupt frimware. They are sending it to me so i'll see how it goes.
                    Cheers.
                    • kmcopier
                      PSP
                      • Oct 2008
                      • 183
                      We have some tools to reset the Flash card complete too Zero. The 2.54 works OK Gr KMcopier
                      • lucky13
                        • May 2008
                        • 125
                        never format the cards
                        never format the cards with tool kit they will be useless
