Bizhub c3110 Replace Toner K
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    I have 2 of these machines both of them doing the exact same thing. It pops up asking to Replace Toner K. I have replaced toners. Replaced the IU. Upgraded F/W. Nothing has made this message go away. Has anyone had this issue and any advice you can share?
    As I was typing this I know have a Bizhub C3100p now doing the exact same thing. This has kinda escalated into an emergency situation.
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Re: Bizhub c3110 Replace Toner K
    Have you seen this thread (same problem)?
    C 3110 - showing replace toner (K)
    Check that first,
    Good luck.
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      Check that first,
      Good luck.
      I've seen that thread and have even posted in it before. The solutions they offer are for Missing IU problems not Toner problems. A resolution was never posted in it either.
      • mo0651
        • 1054
        This goes back to the 4690 series. These machines look for toner dropping thru the chute into the IU unit auger, and how much toner is in the IU unit. If you don't lock the
        toner correctly, or if the foam seal rips off and blocks chute, or if auger in IU unit can't keep up, then you get replace toner. You MUST replace IU and TONER at same time to reset.
        Hate to say it, but that has been the only fix that works. We have tried shaking IU to mix toner. No luck.
        • K-3
          service technician
          • Feb 2018
          • 51
          since you have replaced the toner and iu then check the mechanical of toner replenishment, the sensors seems to work but is the drive to toner cartridge then not working.
          • copier tech
            • 8096
            Simalar issue on the C35 series.
            Try the TNR-CLR in CE mode.
            • tsbservice
              Field tech
              • 7904
              As copier tech said. Try to use ENGINE DIPSW. It is under System 2 > Soft switch > 28 , set this to 1 to force clear toner empty state, then return it to 0.
              Good luck
              • byronf
                Senior Member
                • Sep 2017
                • 109
                Service mode - machine - release mode - new release. Be sure to set it back to NO RELEASE once it detects the toner.
                • srvctec
                  Former KM Senior Tech
                  • Oct 2009
                  • 827
                  Good luck
                  I don't think there is a System 1 or 2 in these small desktop machines.
                  Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                  • tsbservice
                    Field tech
                    • 7904
                    In fact there are SYSTEM 1 and SYSTEM 2 on this machine. It is in Manual.
