Konica Minolta C224e Paper size detecting as 11x17
  • musthafavi
    • Aug 2017
    • 76
    [Misc] Konica Minolta C224e Paper size detecting as 11x17
    Konica Minolta C224e from Tray2 Paper size detecting as 11x17
  • byronf
    Senior Member
    • Sep 2017
    • 109
    Re: Konica Minolta C224e Paper size detecting as 11x17
    [QUOTE=musthafavi;715208]Konica Minolta C224e from Tray2 Paper size detecting
    Change parts below
      • 13227
      What size paper is in the tray? What have you done to troubleshoot problem?
      • tech51
        • 846
        Usually a broken wire on the connector as it plugs into the size block. Easily repairable if you know how to use a soldering iron.
        • musthafavi
          • Aug 2017
          • 76
          Paper size in the tray : A3
            • 22808
            what have you done to correct the issue?
            you need to provide more info if you want a resolve
            • musthafavi
              • Aug 2017
              • 76
              Thanks for your replay, the issue has been solved,
              Feed roller has been changed and its working fine now
                • 22808
                ok a *TIP* anytime you have 'size mismatch' 'false/ghost jams'
                AT LEAST CLEAN THE ROLLERS.. basics.. EVEN in the USERS manual!
                • allan
                  RTFM!!
                  • 5445
                  Not that common but had that before where the wire breaks of right next to the connector.
                  Still not sure how a feed roller fixes a tray size detection problem??
                  Hate those timing jams J-99XX but it point you in the right direction if the machine tells
                  you to check paper size in the tray.
                  Whatever
                  • musthafavi
                    • Aug 2017
                    • 76
                    you to check the paper size in the tray.
                    Before changing the feed roller, I cleaned the paper tray, feed roller and it keeps continue getting the same paper size
                    and finally, changed both feed roller and its working fine
                      • 22808
                      doesn't fit logic for me...
                      unless moving trays got a sensor working...
                      • musthafavi
                        • Aug 2017
                        • 76
                        Yes you are right, again its revert back to 11X7 size,
                        after restarting the printer its detect as A3, after a while or while loading new paper it's detecting as 11x7
                        Please need your suggestions and support to short out this issue, what I will do next
                        • allan
                          RTFM!!
                          • 5445
                          Eish... Its the Width detection sensor on the sensor holder its broken or the wire is broken use a screwdriver to remove the sensor holder to inspect the holder and the sensors the connector and the cable.
                          Whatever
                          • musthafavi
                            • Aug 2017
                            • 76
                            could you please explain, where it is located in Tray2
                            • allan
                              RTFM!!
                              • 5445
                              If you remove the tray at the back inside the machine.
                              Could even find a piece of paper in there.
                              Whatever
