BIZHUB Pro 1051 ( error codes ""0020 and 0413"" )
  • remati
    • 149
    [Error Code] BIZHUB Pro 1051 ( error codes ""0020 and 0413"" )
    Hello friends
    -Several times a day, machine blocks with these codes
    -First 0413 and after that C0020
    For run again,needs to be unlocked by unplugging the wall plug and wait several minutes to turn it back on.
    Any idea??
    thanks people
    • 22920
    Re: BIZHUB Pro 1051 ( error codes ""0020 and 0413"" )
    I think you haven't looked in the service manual yet. =^..^=
    • remati
      • 149
      Yes I have !
      I have all manuals from KM
        • 22801
        Originally posted by remati
        Yes I have ! I have all manuals from KM
        and the manuals told you unplug the LIVE machine? There IS a shutdown process you know.?
          • 22801
          UNLESS he is looking a the USER/ADMIN manual...
          I know those are in there
          • Woxner
            • Jul 2011
            • 825
            0020 code does say to unplug the machine for ten minutes. could be bad adu bd or m22 wire could be pinched. 0413 could also be bad adu 1 or adu 2 or powere supply. 24v interlock problem possible . 0020 also states it could be communication problem between prcb and adu bd
              • 22801
              The OP hasn't replied to " UNPLUG with unit LIVE" yet.. we ALL know several live unplugs can 'screw da pooch'
              I've had users that get an ERROR and yank the live plug....
              we can only wait for his reply
                • 14340
                OP never said he/she unplugs LIVE unit.
                • allan
                  RTFM!!
                  • 5459
                  Me yanking out connectors never got me into trouble yet. Now plunging them in on the wrong socket now that screwed a pooch before.
                  Whatever
                    • 22801
                    unplugging ANY device that has CPU or other sensitive components can scramble memory or fry the chip....
                    • remati
                      • 149
                      Thanks for your serious response.
                      I think you are talking about M32 de-courl motor. Yes I have that note from KM and I had already saw the wiring from the motor to the ADUboard1.
                      Yesterday I fixed one wire that were pinched from the motor conector to the ADUDB1.
                      Machine is working ,but sometimes the error comes again.
                      I ask a new wire kit to the stock parts
                      • Burundi
                        • Sep 2021
                        • 1
                        Hello friends
                        Any idea??
                        thanks people
                        Had this problem . It was a pinched wire on the harness that is on the carriage. Replace harness and it will be ok.
