C558 reset tool?
  • mascan42
    • Oct 2008
    • 480
    C558 reset tool?
    I know there is an MFP reset tool, a firmware file to wipe all settings to factory default on the 4 series machines. Is there something similar for the 8 series? I can't find it on the MKM website.
  • Woxner
    • Jul 2011
    • 825
    Re: C558 reset tool?
    the file is a789be i had to get it from tech suport. pm me your email. will see if it wiil send.
    • karfeilow
      • May 2019
      • 1
      hi woxner!can you send for me this reset tools!very very thx you so much....karfeilow7@gmail.com
      • Max
        • Oct 2011
        • 544
        Hi. Would the same reset tool work on C258?
        • copier tech
          • 8096
          The tool is different for some models.
          For example the C258, C308, C368 use the same tool or SATA recovery firmware.
          • denvertan
            • May 2019
            • 82
            I am also looking for C364e Reset tool.
            Anyone willing to share with me ?
            Post hujacking
            • harnyang
              • May 2019
              • 1
              hello~~woxner! Can you send me this reset tool? Thank you very much...
              mail address:yang156581@gmail.com
              • jotunn
                • 591
                According to KM information, there is no need to use reset tool in devices of 8 series anymore.
                Those machines have eMMC storage instead of SSD, which always has a priority over on-board NVRAM.
                So you can even use a second hand MFP board without resetting.
                In practice - however I didn't test it well - reset tool doesn't even work with newer firmware.
                Even more - i-series, probably will never get reset tool.
                Again, wide-spread counter cheating, killed good service software...
                  • 22801
                  contributors to CTN have a higher chance of getting help and or files.manuals
                  • Copier repairman
                    • Aug 2019
                    • 86
                    What does your last article mean?
                    (Again, wide-spread counter cheating, killed good service software..)
                    • Albonline
                      • Sep 2008
                      • 1131
                      he's talking about crooks who use service tools to defraud customers, by clearing the counters on the units concerned.
                      • rrrohan
                        • Sep 2011
                        • 1977
                        why run a reset tool when you can just "Initialize All" and wipe out everything.
                        what benefit does this reset firmware offer?
                        • jotunn
                          • 591
                          It works like NVRAM Recovery in earlier machines - wipes all the information stored in on-board NVRAM (battery-backup SRAM memory for counters, settings and so on), after resetting, machine recover all that data from backups stored in other places. In the first stage machine recreates structure of the data stored in NVRAM, then re-writes data to recreated structure. The data or structure stored in NVRAM can be damaged by power surged, cosmic rays and so on, leading to strange behavior.
                          In comparison to above, "Initialize All" just resets only some data (user and admin settings, some service settings) to factory defaults.
                          • Copier repairman
                            • Aug 2019
                            • 86
                            [QUOTE = jotunn; 800844] 이전 컴퓨터의 NVRAM 복구처럼 작동합니다. 내장 NVRAM (카운터, 설정 등을위한 배터리 백업 SRAM 메모리)에 저장된 모든 정보를 지 웁니다. 재설정 후 컴퓨터는 모든 데이터를 복구합니다. 다른 장소에 저장된 백업. 첫 번째 단계에서 머신은 NVRAM에 저장된 데이터의 구조를 다시 만든 다음 다시 작성된 구조로 데이터를 다시 씁니다. NVRAM에 저장된 데이터 또는 구조는 전원 서지, 우주선 등으로 인해 손상되어 이상한 동작을 일으킬 수 있습니다.
                            위와 비교하여 "모두 초기화"는 일부 데이터 (사용자 및 관리자 설정, 일부 서비스 설정) 만 공장 기본값으로 재설정합니다. [/ QUOTE]
                            I saw a C308 emmc COPY Tool for sale here.
                            If you copy emmc it will not recover.
                            • Copier repairman
                              • Aug 2019
                              • 86
                              I heard there is an emmc copy tool.
                              Read and save the new machine data with the above tool
                              It is understood that the machine can be used as a new machine data value by writ if necessary.
                              I've seen it somewhere here.
