need FTP Utility 2.0
  • ck1
    • 485
    Hello , Anybody have FTP Utility 2.0 to downloan ?
  • Toxic
    • 694
    Re: need FTP Utility 2.0
    I have v1.0
    • guitar9199
      • Sep 2016
      • 1098
      Information I'm seeing says V2 is not available as of yet.
      • allan
        RTFM!!
        • 5459
        Always used the one from software.informer.
        What is different on V2 why do you need that version?
        Whatever
        • srvctec
          Former KM Senior Tech
          • Oct 2009
          • 827
          I wasn't aware a V2 was even available or in the works, for that matter (the original hasn't been updated in well over a decade, AFAIK).
          The only change I wish they would make would be to make it so you could input a host name vs. IP only. Then, we wouldn't have to go on service calls because Windows did an update and set the PC back to DHCP, thereby rendering the FTP Utility useless when the PC is a whole different IP than what the software was set up for.
          Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
          • allan
            RTFM!!
            • 5459
            On networks with name resolution it works with no problem, not much to do with the app more to do with the machine being able to find the right ftp host.
            So you can use FTP with host names.
            Whatever
            • srvctec
              • Oct 2009
              • 827
              We've never been successful getting FTP Utility to work when a hostname is input in the one touch.
              • allan
                RTFM!!
                • 5459
                Depends if there is a local DNS server on the network and the machine is setup to use it.
                Whatever
                • abbasly.tech
                  • 8
                  FTP utility ver2. is only available to download at KM japan website.
                  • abbasly.tech
                    • 8
                    複合機/複写機:FTP Utilityのダウンロード – ダウンロード – ビジネスソリューション | コニカミノルタ
                    • allan
                      RTFM!!
                      • 5459
                      Downloads and installs ok. My Japanese reading sucks bad today.
                      English ver would be nice.
                      See that the setup has more option. What is the difference from V1.0?
                      Whatever
                      • BaconSteve
                        • Apr 2019
                        • 140
                        • ck1
                          • 485
                          got any software can use for konicaminolta scan FTP due to some PC cant use FTP utility .
                          • JR2ALTA
                            • Feb 2010
                            • 2027
                            Look right above you.
                            • darry1322
                              • Oct 2010
                              • 817
                              I've seen this one get recommended before. Loads and sets up pretty easily.
                              Quick 'n Easy FTP Server Lite
