Bizhub C258 & Office365 Scanning
  • Leebs14
    • Feb 2014
    • 457
    [Misc] Bizhub C258 & Office365 Scanning
    Firsty I apologise if this has been previously covered, which I am guessing it has, but I couldnt find anything through the search function.
    My customer IT people have migrated them to Office365 and have failed to get the Bizhub scanning, so I was asked to help. they are trying to use a generic email address (scanner@Companyename.co.uk) as the scanners address and are using an office365 account details as the smtp authentication but when they send a scan the machine says its sent complete in its log but the scan never arrives? Its not in junk or anywhere, it's not even showing as arriving at the Office365 smtp server??
    So I set the machine up using my own office365 set up including my email address and it worked first time every time to all the staff, but the email was being sent from my office365 email address. I have told the IT guys that as far as I am aware Offic365 needs to validate the email address against the username/password authentication ohterwise it won't work, but they are not having it, they're saying it should work with a generic email address??
    All I know is my customer is getting 'cheesed off' with it not working and I am asking for advice on how i can get this to work or to know why it won't work as they want it to?
    Hope this makes sense???
    • 22801
    Re: Bizhub C258 & Office365 Scanning
    hard headed IT "guru's " are the bain of a copier techs lives.
    IF if worked on your setup and not on theirs..
    wonder which is correct? hmmmm
      • 8060
      Scan to email from Office 365 requires:
      - Authentication. A made up fictional email sender address is not likely to work.
      - Mandatory use of TLS 1.2 for SMTP
      - The Sender Address requires start and stop with Angled brackets.
      • tsbservice
        Field tech
        • 7899
        Those IT bods are complete morons. If it's working with your setup, why they blame you not their settings.
        The sending email address used by the MFP must be a valid office 365 email address.
        • Synthohol
          Certified Konica Expert
          • 5727
          agreed.
          • CompyTech
            Super Tech
            • Feb 2011
            • 706
            Gmail is the only one that I know of that allows scan to email like that using their "restricted" server. I guess you could tell them to give you a valid email account from Office365 for the copier or switch everyone over to gmail..
              • 22801
              The customer's IT dept requires Office 365
              Not much he can do when pinheads are involved.
              IMHO any product from MS is vulnerable and should be avoided.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4511
                Go to the head person, manager, etc and tell them you have set up your own network with your laptop and it works fine. You explained to the IT people what you think is causing it and they don't want to listen. Tell them your job is done! You have confirmed it has nothing to do with the copier.
                Also not sure if it was for the "8" series but for the "4" series there was a bulletin about scanning to email with office 365. Not sure if this is same thing.
                • rrrohan
                  • Sep 2011
                  • 1977
                  I put the settings onto a email software on a PC and see if it works.
                  You maybe getting a bounce back reply from server that copier obviously can receive.
                  Often it explains why it bounced
                  • Bix
                    • Apr 2018
                    • 1421
                    Sometimes they use normal unprotected ports, such as port 25.
                    • delboy10
                      • Jun 2010
                      • 43
                      You are right about valid email for authentication. You can check out this link and send it to them.:
                      How to set up a multifunction device or application to send email using Office 365 | Microsoft Docs
                      more likely option 2 or option 3
                      delboy
