TWN4 Card Reader on Bizhub 363
  • proteuss
    • Jun 2013
    • 5
    Hi there, can someone help me with a driver so that my TWN4 USB card reader can work on my Bizhub 363?
    Thank you
  • Synthohol
    Certified Konica Expert
    • 5731
    Re: TWN4 Card Reader on Bizhub 363
    Downloads
    They would be the ones to ask because that's not the type or brand konica officially supports.
    • proteuss
      • Jun 2013
      • 5
      Thanks but I already contacted them and said that I should contact KM to get the driver.
      Since I am not a KM technician they will not give me the driver...
      • Synthohol
        • 5731
        Konica publishes drivers for specific ones they support.
        Which one is closest to yours?
        • proteuss
          • Jun 2013
          • 5
          I don't think KM is using this types of card readers, I know they are used with PaperCut, Equitrac or other management softwares and work on KM machines if they have the right driver.
          • Synthohol
            • 5731
            i dont want to see you brick the machine from the wrong stuff.
            just an FYI...
            Card Readers
            AU-201H HID Proximity Card Authentication Unit HID Proximity Card Authentication Unit 7640005064
            AU-202H HID iClass Card Authentication Unit iClass Card Authentication Unit 76400083948
            footnote 8...
            8 bizhub 652/552/C652DS/C652/C552DS/C552/C452 and bizhub 423/363: AU-202H, Indala Card Reader, Mifare Card Reader requires WT-506 Working Table; bizhub 283/223: AU-202H, Indala Card Reader, Mifare Card Reader requires HD-516 Hard Disk Drive and WT-506 Working Table; bizhub C360/C280/C220: Requires WT-506 Working Table. If WT-507 Working Table (Side Panel Kit) is installed, it can be used to mount the AU-202H. bizhub C754e/C654e/C754/C654/C554e/C554/C454e/C454/C364e/C364/C284e/C284/C224e/C224 and 754/654: AU-202H requires WT-506 Working Table or MK-735 Mount Kit to install internally, C3100P: Requires HD-P06 Hard Disk Drive.
            i can give you the 201H driver but i only share files with contributors. not to be a d%#k, its just id like to see this forum become self supporting without the silly ads.
            • emujo2
              • Mar 2017
              • 1580
              In order for a card reader to work on a KM device, you have to install a driver (LDD) that tells the device how to use the card reader. The 363 has support for the AU-201H (HID Prox) , AU-204H (mag stripe), and the RF Ideas AK0 (MiFare) reader. Nothing else will work unless you know how to build driver files..E
              • proteuss
                • Jun 2013
                • 5
                Maybe you are right but I talked to Elatec and PaperCut and they both said that KM has the drivers for this device and I should contact them.
                • tsbservice
                  Field tech
                  • 7904
                  So you prefer to trust Elatec and PaperCut not techs here, many of them well known for their vast experience with KM boxes. It's up to you if want to risk and install wrong driver after becoming contributor.
                  Good luck.
                  • B0265
                    • Jan 2007
                    • 718
                    I have seen a list of loadable drivers from KM Europe. There are Elatec drivers available for newer models but Bizhub 363 isn't listed.
                    • emujo2
                      • Mar 2017
                      • 1580
                      Post a pic of the card reader back and front..If it's a re branded RF Ideas or HID maybe we can help..but again TWN4 is not listed as a supported reader.
                      • emujo2
                        • Mar 2017
                        • 1580
                        OK I looked myself..this is an Elatec reader and KM does offer LDD for it..Unfortunately, support is for the latest A3/A4 devices. The 363 is not and never will be supported. If you were to try this LDD you would wind up with a non functioning MFP.
