C458 Function Version 3.2 to 4.2
  • furius
    • Jan 2018
    • 34
    Hi guyswould like to update the graphic interface(function version) of a bizhub c458 to version 4.2.
    Although installing the latest firmware avaible, but the machine remains at function version 3.2
    Tips?the latest firmware available
  • 907tec
    • 436
    Re: C458 Function Version 3.2 to 4.2
    Have you checked the Firmware Notes associated with the FW that you loaded? They generally include steps for upgrading/downgrading function version towards the bottom of the notes.
    • emujo2
      • Mar 2017
      • 1580
      Soft switch 25 sets the function version..I believe it would be A0 for 4.2..Keep in mind that a function version upgrade may add some new protocols or even remove something..so you can induce problems with scanning and printing..E
      • Synthohol
        Certified Konica Expert
        • 5733
        B0 is the latest for w firmware.
        • tsbservice
          Field tech
          • 7904
          Nope, soft switch for function version 4.2 must be B0 as Synthohohol mentioned. Check file coming with FW version to level other software, drivers, etc.
          • rrrohan
            • Sep 2011
            • 1977
            also make sure the driver support version 4 and on
