Restart the printer remotely
  • Bix
    • Apr 2018
    • 1421
    Hi, do you think there is a way to restart the printer remotely?
    With the WWRSPF it is possible to enter the administrator panel. But sometimes, you need to turn off and on the printer. Is there any setting in the service mode to reboot without asking the customer to turn it on and off?
  • emujo2
    • Mar 2017
    • 1580
    Re: Restart the printer remotely
    A controller reset does not require power cycle, anything else that prompts "turn power off" requires someone to cycle the switch. E
    • Bix
      • Apr 2018
      • 1421
      I don't know if you've seen, the WWRSPF has arrived. This will also allow you to update the firmware remotely but you need to change the dipswitch for the version.
      To apply the changes, a reboot is required but it cannot be done remotely. For example, in the 8 series enabling the browser it was possible to restart it. In iSeries unfortunately they do not restart if you enable the browser
      thank you
      • emujo2
        • Mar 2017
        • 1580
        I have no idea what
        WWRSPF is..maybe you can explain what this stands for..E
        • Jumping Jack Flash
          • Jul 2009
          • 61
          thank you
          IP host / DNS: 50443 / Panel / reboot.cgi
          the .cgi command must be run in the web server directory of the remote panel using a browser.
          And that's about it
          • Bix
            • Apr 2018
            • 1421
            Originally posted by emujo2
            I have no idea what
            You can find the WWRSPF on Infohub. It also integrates with CSRC from what I understand. This new tool allows you to connect to the screen of the multi-function printer in real time, without having to necessarily require the pin. Also you can update the firmware, make backups, debug and more, staying at your office.
            • tsbservice
              Field tech
              • 7897
              I have no idea what WWRSPF is..maybe you can explain what this stands for..E
              That is definition but I can't speak what it actually does from my experience.
              ''WWRSPF (World Wide Remote Service Platform) carries out SSL communication and data storage in communications between all communicating devices and systems.
              It also delivers secure communication by preventing spoofing through measures such as client server authentication, Global IP address restriction for senders, and native XMPP IDs, etc.''
              • Bix
                • Apr 2018
                • 1421
                And that's about it
                Thanks, this is interesting but it has not been successful for me
                Is there any dipswitch to enable before?
                Bix
                • emujo2
                  • Mar 2017
                  • 1580
                  maybe you are speaking of remote panel..There are 2 RP services, client and server..I've only ever setup server..this allows the MFP screen to be shown in a web browser window exactly as you would see as if you were standing in front of it. RP client required you point to a server running some kind of software. I think this is what that WWR**** may be. E
                  • rrrohan
                    • Sep 2011
                    • 1977
                    I just tried the remote reboot on a old non E C754 and it gave internal error E301 but I guess it did technically cause a reboot lol
                    • Bix
                      • Apr 2018
                      • 1421
                      Yes, there are still some problems if the firmware is not updated. Sometimes FA14 also happens.
                      I tried it on a bizhub 4052 but without success. I have tried both from PC and directly from the browser of the multifunction printer. For example:
                      I forget something?
                      • rrrohan
                        • Sep 2011
                        • 1977
                        I forget something?
                        im guessing remote panel server needs to be setup. and if you use password authentication on remote panel you might need to first login to remote panel via the usual URL before loading the reboot.cgi URL
                        • Bix
                          • Apr 2018
                          • 1421
                          Yes, the server is configured.
                          There are no problems accessing https://192.168.1.11:50443/panel/remote_panel.cgi
                          • rrrohan
                            • Sep 2011
                            • 1977
                            isnt the 4052 a lexmark rebadge? might be something to do with it
                            • tsbservice
                              Field tech
                              • 7897
                              Then you can enter Service mode - Enhanced security - Engine FW DipSW and from there REBOOT machine remotely.
