Bizhub 3622
  • Schneider
    • Sep 2018
    • 25
    Bizhub 3622
    Hey All
    Anyone know how to stop these machines from printing a Scan Log after each email scan?
    I turned off the Log Report option in email admin settings but it still prints the reports. I had to change the report page default tray to bypass to stop it wasting paper.
    The manual has been nothing but helpful and a firmware update also did not help.
    Thanks in Advance.
  • copyrooks
    • Oct 2013
    • 206
    Re: Bizhub 3622
    I tried this on a bizhub 3322 i hope this helps.
    Settings
    Email Settings/FTP Settings
    Email Settings
    Look for Transmission Log
    Switch it to Do Not Print Log
      • 14328
      Re: Bizhub 3622
      You have to edit the shortcut you created and turn off transmission log. Turning it off in settings does nothing.
      • Woxner
        • Jul 2011
        • 825
        Re: Bizhub 3622
        Solution
        CAUSE: Transmission logs are enabled.
        SOLUTION: Perform the following steps to resolve the issue.
        1. To disable transmission logs a shortcut needs to be created via EWS, Perform the following.
        a. Access EWS to change the shortcut you wish to change.
        b. Change the transmission log to either [Print Log], [Do Not Print Log] or Print Only For Error].
        c. Click Save.
        2. To create a new shortcut to set the transmission log functionality desired, perform the following.
        a. Access EWS Settings and select E-Mail
        b. Select E-Mail Defaults
        c. Select Admin Controls
        d. Select either [Print Log], [Do Not Print Log] or Print Only For Error].
        e. In EWS, select shortcut
        f. Select add shortcut
        g. Select E-mail and set necessary place
        h. Click Save
