C360i firmware update problem
  • SUPERMIGHTYZ
    • Jan 2013
    • 13
    [Misc] C360i firmware update problem
    I can't update firmware on the bizhub c360i series. I copy the firmware folder (FW000XX) to the root of the usb stick, but it does not start. The dot appears but then nothing ..Thanks to everyone who will help me Thanks to everyone who will help meI can't update firmware on the bizhub c360i series. I copy the firmware folder (FW000XX) to the root of the usb stick, but it does not start. The dot appears but then nothing ..Thanks to everyone who will help me
  • Synthohol
    Certified Konica Expert
    • 5731
    Re: C360i firmware update problem
    did you forget to hold down the "secret" red button on the panel while booting?
    • tsbservice
      Field tech
      • 7904
      Apparently, not.
      • tech51
        • 846
        • Synthohol
          • 5731
          Apparently, not.
          well he didn't say he did
          and then repeated himself in a different font.
          just an odd post even if its a translation.
          • Woxner
            • Jul 2011
            • 825
            you should use a 3.1 jet flash. that is what is recommended on these otherwise it might not work. dont go above version 45 yet. its FW0020 thats the only folder you need
            • SUPERMIGHTYZ
              • Jan 2013
              • 13
              Thanks for the answers. I tried various 1GB, 4GB, 8GB, usb2, usb3 usb key and in any case the firmware does not update.Yes, I copied the FW0020 folder to the root of the USB KEY and turned the machine on while holding down the "RESET" button hidden behind the display door.
              Thanks for the answers. I tried various 1GB, 4GB, 8GB, usb2, usb3 chievette usb and in any case the firmware does not update.Yes, I copied the FW0020 folder to the root of the USB stick and turned the machine on while holding down the "RESET" button hidden behind the display door.
              • Bix
                • Apr 2018
                • 1421
                Hi, the RESET button is for the TROUBLE RESET. In this case the word for error erasers should appear.
                The RED button (stop) is what you need to use for the firmware. It may take about 1-2 minutes before something happens.
                • emujo2
                  • Mar 2017
                  • 1580
                  OK..lets assume you have the right firmware, loaded correctly on a working USB drive...Power on/button pressed, black dot appears, nothing happens..How long are you waiting before giving up, and what is the reason for the firmare update in the 1st place..If it's somehing like MFP would't boot, or I replaced MFP board, that info would be nice..E
                  LOL had to do it twice..
                  • tsbservice
                    Field tech
                    • 7904
                    USB formatted as FAT32?
                    Somebody restricted from Admin menu USB Firmware Update?
                    Did you try different FW versions?
                    • SUPERMIGHTYZ
                      • Jan 2013
                      • 13
                      I have tried different Firmware downloaded from the official website. USB stick formatted in FAT32. No restrictions in the "Firmware update" menu.The button that I keep pressed is the "STOP", the bullet appears but nothing happens and the copier starts normally as if it didn't read the USB key
                      • SUPERMIGHTYZ
                        • Jan 2013
                        • 13
                        Problem solved. Key usb! Thanks
                        • lillingtonnc
                          • Apr 2015
                          • 8
                          i know this is old thread, but i have had issues with FW0020 on root of usb and i have had issues puuting it in FWSelect. Sounds stupid but it always works works when i put it on usb twice, on root and in FWSelect folder. Don't know why, just know it works.
                          • bowser222
                            • Sep 2020
                            • 6
                            glad you solved it.
                            • copier tech
                              • 8095
                              You don't need to bother with the FWSelect folder.
                              I keep multiple models with just the FW00020 folders etc on one 8GB USB pen drive.
