Awakening from causal energy savings
  • Bix
    • Apr 2018
    • 1421
    Hi,
    I had several bizhubs in the office, from the oldest to the most recent iSeries. Most of them have standard energy saving configurations. Sometimes, for no apparent reason, they wake up from energy savings. This happened to me on Bizhub C258, 4052, C300i etc.
    I never found a definitive solution, I tried to reduce the sensitivity to "touch the panel to wake up from saving energy" to -2 but without great results. The only definitive solution is to deactivate the awakening by touching the panel but to some it might be annoying to wake up the screen with a button.
    Do you have any experience and advice?
  • tsbservice
    Field tech
    • 7897
    Re: Awakening from causal energy savings
    Bix, our office machine C250i was doing the same. As I usually arrive first in the morning machine maybe 1 or 2 times per a week wasn't in sleep mode.
    Such things irritates me, because I don't know why it's happening. I deleted/removed all Marketplace crap that seems to help.
    As you have mixed fleet between models I don't know what to advice regarding older ones, but keep digging
    • copyman
      Owner / Technician
      • Sep 2005
      • 4511
      I have also seen this before but never really found an answer. I always turn off the sleep mode because of the issues with the 3 & 4 series waking up. Don't some Kon/Min models have a feature that senses when you walk near machine and it wakes up?
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2140
        Known issue on early i series to continuously wake from sleep mode. 30% of early panels have a grounding issue in relation to the proximity sensor.
        Panel replacement is not required. An additional ground wire from panel frame to proximity sensor fixes the problem. This is my self made cable, I did not have smaller terminals to use. KMBT is looking at providing conductive foil tape as a solution.
        The fix is very easy and it works.
        Bulletin for reference; PSKM_BT1928457EN
        • copier tech
          • 8091
          Originally posted by Bix
          Hi,
          This is caused by temperature & humidity fluctuations the machine does a warm up cycle to prevent condensation etc.
          • tsbservice
            Field tech
            • 7897
            [ATTACH=CONFIG]44301[/ATTACH]
            As you have turned off PMs I have to ask you here, from where you get that bulletin? Can't find it in mykonicaminolta.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2140
              May not be public in your country.
              On the i series, just press the power button on LHS of panel and wait up to 10 minutes, if it wakes up by itself with no reason this will be the cause.
              On the one I had - press the button and within 10 seconds, bang it was on again, every time.
              Attached the grounding wire as per the bulletin and problem solved.
              • Bix
                • Apr 2018
                • 1421
                It seems strange to me because if I deactivate the awakening by touch on the panel, the C250i does not turn on by itself.
                I think I consider the grounding hypothesis. But is it a forgotten piece or just a lack in the first released MFPs, like the thickness for the toners?
                I happened to disassemble a panel in the 8 series and if I'm not mistaken, that cable is present. Now I understand its usefulness
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2140
                  The floating ground for the proximity sensor is because of the conductive foam used in the early panels is not conductive enough.
                  The addition of the ground wire as per the image solves the problem.
                  • Bix
                    • Apr 2018
                    • 1421
                    thank you!Any advice on where to recover such a cable, even from other MFPs? Until now, I found only 50cm long cables
                    • tsbservice
                      Field tech
                      • 7897
                      Yep, finally caught our office machine doing exactly what you describe. That needle me enough to make a quick ground connection from a paper clip and insulating tape.
                      Now it sleeps. EKmT rocks!
                      • occus
                        • 317
                        It's the same for the 250i Series? or only for 258?
                        • Bix
                          • Apr 2018
                          • 1421
                          also applies to ineo 250i
                          However does anyone know where it is possible to find a wire ground from some MFP or part list?
                          • EarthKmTech
                            Step aside, noob
                            • May 2009
                            • 2140
                            I made my own cable.
                            PS the bulletin is strictly in relaition to I series.
                            I'm unaware of a problem with 8 series but if it works on them too id be interested to know, as would KM
                              • 22914
                              Good to know! Thanks for sharing. =^..^=
