Fiery server problem IC-413
  • blazy
    • Dec 2019
    • 20
    Hello everyone,
    I have problem with my fiery server IC-413, and the thing is that is stuck at Starting windows Logo.
    First problem was that my hdd with windows xp (fiery v1.0) broke down and was not recognised anymore. So I tried to install newer version of Fiery v1.1 to a brand new SSD. After I did that, the windows started, I could sing in to Admin normaly. After a couple of seconds the Fiery started to shutting down process. After attempt to restart it, fiery got stuck on Starting Windows Logo and I can not boot anymore.
    I could try to reinstall the older version of Fiery (v1.0) but I don't have one. Please contact me via PM if someone is willing to share it with me.
    If anyone has a solution, I would be very greatful.
    (Sorry for my English)
  • tsbservice
    Field tech
    • 7897
    Re: Fiery server problem IC-413
    First - your English is better than mine, so don't worry bout that
    Second - first post and already Contributor, Thank you for supporting CTN!
    Third - I see only Version 1.11 Software on my part.
    Fourth - if Synthohol(one of our members) is not around I will try to ask him to help you.
    Fifth - Good luck and don't forget to follow up here.
    • Synthohol
      Certified Konica Expert
      • 5727
      I have very 1.11 and very 2.0
      2.0 requires a bios and memory upgrade or it will crash.
      I can PM you a link to 1.11 if you like?
      Also check the CPU cooler, the tabs used to break causing overheating.
      As far as the win logo loop, try hitting f6 after the post and see if you can boot in safe mode.
      Also you used an SSD hdd?
      I wouldn't bother because it won't make a difference in speed as XP does not use TRIM properly and the OS may not be partitioned correctly. These old units like the old hardware.
      • blazy
        • Dec 2019
        • 20
        Hi, thank you for your answer.
        I am allready using your v1.11 version of fiery. I have tried installing with hdd and cleaning cpu heatsink and applying new thermal paste. The results were the same.
        Because I couldn't make a bootable device with USB I tried with old school method by running off an DVD Drives. Could that be cause of the problem ?
        • methogod
          • Dec 2008
          • 915
          should be able to do the win7 upgrade...
          not sure why not, ram is available.
          see if anyone can help with bios update....
          • blazy
            • Dec 2019
            • 20
            I am using your version, but it's not working. I tried cleaning cpu cooler and applying new thermal paste. Safe mode boot doesn't work, tried installing it on HDD still not working. Also tried to make a bootable USB, and I can not manage it to boot.
            Does anyone have old v1.0 version of fiery ?
            • Synthohol
              • 5727
              I have the fiery manual but it's at home where my server is. Maybe someone can send it to you or you will have to wait until I get home tonight to upload to my server.
              • Synthohol
                • 5727
                Maybe you are not prepping the usb correctly.
                Have a look.
                • blazy
                  • Dec 2019
                  • 20
                  I can wait, thanks!
                  • Synthohol
                    • 5727
                    hey, here are the Ethernet install instructions.
                    any issues post here and ill see if i can help.
                    pretty straightforward as ive done this type of install well over 100 times. (LOL not on same fiery)
                    • blazy
                      • Dec 2019
                      • 20
                      But your version does not support this kind of installation. I got a hold of old v1.0 software with windows xp, and I got everything working but the problem is that my KM PRO 6000L says that "Controler is not connected". On the CWS it says "Establishing serial connection". I tried to clean connectors and the error is still the same. Do I need any patch to make it work ?
                      • arahael
                        • Mar 2013
                        • 96
                        yes. you need patch 18ldjr
                        • Synthohol
                          • 5727
                          PM sent
                          • blazy
                            • Dec 2019
                            • 20
                            Thanks everyone, I finaly got it working!
                            • marli
                              • Feb 2019
                              • 12
                              can you send me a copier of old ver 1.0 for ic-413?
