Update firmware for bizhub C224e
  • maximus-1994nr
    • Dec 2018
    • 12
    When I try to update the driver for the printer, I get a message "drivers used by connection printers are not to be updated". Who faced this and how to solve the problem?
  • Synthohol
    Certified Konica Expert
    • 5731
    Re: Update firmware for bizhub C224e
    talk to their IT person, that has nothing to do with the machine.
    is it using simple tcp/ip port or something stupid and amateur?
    why is the driver being updated?
    what OS?
    PS? PCL? XPS?
    almost like putting a jigsaw puzzle together upside down.
    could use just a bit more info if you want an educated answer.
    • maximus-1994nr
      • Dec 2018
      • 12
      Sorry, I agree, there is little information.
      Used ip port. The old driver version 4.1.0.0 is installed and I'd like to upgrade to the new version 5.3.0.712
      OS: Win10 x64
      PCL
      • Synthohol
        • 5731
        is it a requirement of the version of firmware on the machine?
        is the driver newer than the FW?
        is there a printing issue? or any enhancements to the driver?
        I'm genuinely curious, for real.
        • copier tech
          • 8095
          Just perform a new install rather than updating the old driver. Once you get this working delete the old one.
          If you still get the same message update the firmware & function version.
          • maximus-1994nr
            • Dec 2018
            • 12
            Yes, the driver is newer than the firmware version.
            Sometimes there are problems with printing, especially with printing on an envelope, I decided to update that maybe this will fix our issue.
            • maximus-1994nr
              • Dec 2018
              • 12
              Thank you so much, everything worked out. How did I not immediately think of this ?!
              • copier tech
                • 8095
                Cool cheers for the update
                • tsbservice
                  Field tech
                  • 7904
                  Because he is copier tech and you are clearly not
