Bizhub C6000/7000 Error code C-281X
  • tulintron
    • Jul 2014
    • 665
    I followed the advice of lucky13 in this post above, but to no avail.
    Any tips that might help?
    Thanks.
  • cricketsi
    Field Tech
    • Feb 2020
    • 14
    Re: Bizhub C6000/7000 Error code C-281X
    Might seem like a dumb question, but are the corona's good?
    • tsbservice
      Field tech
      • 7904
      Check the connection of the process carriage drawer connectors for proper connection.
      • tulintron
        • Jul 2014
        • 665
        new cargo corona and process car mechanism operating perfectly and clean
        • cricketsi
          Field Tech
          • Feb 2020
          • 14
          Ok, you had mentioned the C6000 doesn't have potential sensors, but it does. Still same spot under dev units.
          At least, that's what I remember...lol. It's been awhile.
          • tsbservice
            Field tech
            • 7904
            PM send.
            • wjurls
              • Feb 2017
              • 490
              C-281* Isn't related to the toner density or the TCR sensors. It's due to an error while undergoing gamma correction. Gamma is done by drawing a patch of color and it's density is read off the transfer belt by the IDC sensor. If the IDC sensor is dirty, or the solenoid/shutter isn't working it can result in the C281* code. Problems with the trans belt cleaning, drum, coronas, or a dirty slit glass can also affect it.
              Toner density can affect it, but a depleted developer will likely throw a C242* code.
              • tulintron
                • Jul 2014
                • 665
                Yes, exactly!
                However, I notice that the black color is formed with a lighter density than the other colors, that's why my case C-2814.
                When Recall is performed within the Process Adjustment, the equipment operates normally for a while, around 600 pages, but soon shows C-2814.
                In fact, it happened right after doing a great job with high black coverage. Then a new job with zero black coverage. Started the mistake that won't let me sleep ...
                • wjurls
                  • Feb 2017
                  • 490
                  Yes, exactly!
                  You get a visibly light patch even right after loading fresh developer? Is the "dust proof glass" clean?
                  • sadanand
                    • 62
                    dip sw 11-0 change to 1
                    • Toxic
                      • 694
                      Some info for what dipsw is would be nice.
                      • tsbservice
                        Field tech
                        • 7904
                        PM sent
                        • sadanand
                          • 62
                          by changing dip sw 11-0 from 0 to 1 you can disable error code then find out which colour has problem max times problem is with black or cyan
