Bizhub 758 , restart after printing
  • pinspin
    • Oct 2011
    • 156
    Hello, the copier restarts when it receives a print job from the network . C D341, C D262 errors are recorded while. Disconnecting the HDD does not help. Firmware upgrade also does not start . We will be grateful for any advice, thanks.
  • Bix
    • Apr 2018
    • 1421
    Re: Bizhub 758 , restart after printing
    Hi, don't disable HDD or do anything.
    After 3 reboots, the 758 will display "Recover data". You press on recover data and the MFP will recover after reboot.
    This happens when communication occurs between boards for meters and other information (about every hour) and at that moment there is a power blackout or something abnormal.
    • tsbservice
      Field tech
      • 7906
      I will proceed like that:
      1. [System 1] -> [Initialization] -> [Clear All Data]
      2. Backup the HDD, format the HDD(s).
      3. Run in Service Mode -> [State Confirmation] -> [Self-diagnostic] -> [Check All]
      Also worth to mention that CD262 is about - Extension network adapter installation error - Wireless LAN Upgrade Kit (UK-212) not correctly installed or has failed.
      So if any installed, check them.
      • pinspin
        • Oct 2011
        • 156
        It was a problem with the contacts on the boards.
        • maycondb
          • Jun 2023
          • 1
          which boards?
