My bizhub c224e copier does not start.
  • r6po
    • Apr 2020
    • 15
    When I light the main button, the screen lights up, there are 2 bars, I hear a beep, the start button lights up then it restarts
    In addition, in recent weeks it has been impossible to access the copier via the web interface.
    Can you help me identify the fault?
    SSD? Firmware ??
    Thanks for your help.
  • Synthohol
    Certified Konica Expert
    • 5734
    Re: My bizhub c224e copier does not start.
    try reseating the ram and SSD.
    if no change try disconnecting the HDD, even if it goes into error it still shows signs of possible life.
    try firmware.
    • GIUBOSS
      • 1382
      SSD? Firmware ??
      if you are not a qualified technician, it is not recommended to operate as such in order not to make the situation worse
      • copyman
        Owner / Technician
        • Sep 2005
        • 4512
        Sounds like SSD. If all else fails try reset firmware. A lot has been posted on this forum about this issue
        • Ari007
          • Apr 2019
          • 49
          Press & hold "reset" and turn the power button on. See if the reset page is coming or not?
          • r6po
            • Apr 2020
            • 15
            try firmware.
            OK I'll take a look.
            Thank you
            • r6po
              • Apr 2020
              • 15
              It's the same thing :/
              no reset page...
              • r6po
                • Apr 2020
                • 15
                Thanks for the advice
                • r6po
                  • Apr 2020
                  • 15
                  I removed the memory module.
                  I have the impression that the copier is starting, I hear the noise of the mechanism. But I have nothing left on the screen.
                  I had 2 old 512MB DDR2 (jecrois) bars, I put them same reaction.
                  When I put back the initial bar, I find the problem before with the screen and its 2 bars.
                  Do you think it's the 2 GB strip.
                  What is the minimum memory requirement to operate a C224e?
                  • GIUBOSS
                    • 1382
                    V865300066 MEMORY MODULES 2GB . You tried to clean the contacts of the memory module by rubbing the contacts.
                    • Albonline
                      • Sep 2008
                      • 1131
                      try removing dual scan driver board.
                      • ivovb
                        • 695
                        I'm 99.99 % sure it is SSD! Anyway in order to make it 99.99999999 % can You tell current firmware version?
                        BR
                        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          I think you should stop you could give yourself more problems call a credited service engineer good luck
                          Regards Mark
                          • Albonline
                            • Sep 2008
                            • 1131
                            BR
                            most ssd failures would just freeze, not restart. you have something keeping the mfp from starting. eg dead accessory or other load. this case sounds like a shorted load. hdd or daughter board.
                            • ivovb
                              • 695
                              Not mine statistic...
                              BR
