Bizhub C3100p error
  • copicatt
    • Nov 2008
    • 366
    Bizhub C3100p error
  • tsbservice
    Field tech
    • 7899
    Re: Bizhub C3100p error
    Start with reseating connectors.
    • Edgar Uk
      • Apr 2019
      • 6
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        Originally posted by Edgar Uk
        Check the rear of the fuser is pushed in & connected correctly. You can get this error if it isn’t.
        HUH?!
        The fuser is basically at the top of the machine while the laser unit is clear at the bottom with lots of other stuff between the two. Unless they both get power through the same circuit, which I seriously doubt.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • Edgar Uk
          • Apr 2019
          • 6
            • 22916
            Funny that you mention that ... I've seen that too on a C25! If the customer latches the front of the fuser, but not the back they'll get 0130 (laser shutter malfunction) and 0094 (second transfer drive failure). The way I figure it the doorswitch actuator opens the laser shutter. =^..^=
            • srvctec
              • Oct 2009
              • 827
              I hope reseating the fuser does work and if it does, I will have learned something, which I love doing.
              • copicatt
                • Nov 2008
                • 366
                Here is what I did:
                I first reseated the connectors on the boards in the back (MFP/PRCB). Didn't work. So i dove in and removed the PH (Laser Unit). Lord what a job. I reconnected the connectors at the laser unit and reassembled it all. It is now working!!! Didn't touch the fuser.
                Thanks for the help!
                • Edgar Uk
                  • Apr 2019
                  • 6
                  Great to hear you fixed it but out of curiosity why not check the fuser first as that would take less than 10 seconds and if it had been that then it would have saved taking a machine to pieces?
