Bizhub 4702/4572 POR
  • emujo2
    • Mar 2017
    • 1580
    [Misc] Bizhub 4702/4572 POR
    How is the POR reset done on these machines..SM says perform POR to get onto various menus..No explanation of the required key sequence for the POR? TIA, Ed
  • copyrooks
    • Oct 2013
    • 206
    Re: Bizhub 4702/4572 POR
    edited
    • tsbservice
      Field tech
      • 7904
      As POR means Power-On Reset sometimes POR just means to turn off/on device or to turn it off/on and enter Diagnostics menu, etc.
      • tsbservice
        Field tech
        • 7904
        He has manual and knows how to use it...please just edit your post, it's super helpful as always...but regular endusers easy may defy havoc for poor next tech trying to repair their "work".
        • emujo2
          • Mar 2017
          • 1580
          My exact need is to get into the configuration menu to reset the Maintenance parts low service check message..
          To reset the maintenance counter:1. POR into the Configuration menu, and navigate to Reset Maintenance Counter. 2. Depending on the printer model, press OK to reset the counter, or press X to exit without resetting the counter.Once initiated, the operation cannot be canceled.
          • emujo2
            • Mar 2017
            • 1580
            So..the only info KM can provide is based off the 4700P manual (as it seems that the 4702P manual is cut and paste for the most part). The POR is, as I suspected, holding down a certain set of keys and applying power..Like a trouble reset..The 4700 manual says to hold down #2,#6 (I think) to enter POR and access the config menu. Since the 4702 SM does not list this step, support is simply assuming the 4700 procedure should be the same..It's not. Pressing this key sequence does seem to bring you to config, but no other keys work at this point. E
            • Synthohol
              Certified Konica Expert
              • 5733
              Service Engineer menu
              Entering Invalid engine mode
              This mode allows the printer to load the correct firmware code.
              1. Turn off the printer.
              2. Press and hold 3, 4, and 6 while turning on the printer.
              3. Release the buttons after 10 seconds.
              Entering the Service Engineer (SE) menu
              To access the Service Engineer (SE) menu:
              1. Turn on the printer.
              2. When the home screen appears, press * * 411 on the control panel.
              General SE
              This setting allows you to save a log file to a USB drive.
              Enter the Service Engineer (SE) menu, and then navigate to:
              General SE >Capture Logs to USB Drive
              Press [OK] to navigate through the settings.
              Network SE
              Enter the Service Engineer (SE) menu, and then select Network SE.
              Note: Use these settings as directed by the next level of support.
              • strider5555
                • Jun 2008
                • 96
                To clarify, are you referring to the MFP 4052/4752? If so you do new release for the maintenance kit in service mode.
                • After replacing a maintenance kit or stapler, perform New Release to clear its life counter.
                • Touch [Counter] -> [Life] -> [New Release].
                • Open the front door.
                • Select a unit where New Release is made.
                • Press the Start key and perform New Release.
                If it is for the 4702P printer, you reset the maintenance counter through the config menu from the settings key, device, maintenance, config, supply usage and counters. The user manual isn't all that clear on that. As for POR on the 4702P, from the machine ready or home screen, press **36. To exit press the back key or power off/on
                • emujo2
                  • Mar 2017
                  • 1580
                  Update..I went with the tech on site to get the whole story..We have 2 of these side by side at an account. Both were placed the same day...
                  The 4700 SM seems to be correct when appled to the 4702P..On the 2nd machine '2" "6" and Power On does run through a sequence ending up in config menu. On the 1st, the same sequence displays "No logon configured" OK. Touching Ok does nothing. We are able to enter service and admin mode with another POR. I'm thinking there is a secrity setting enabled to get into config menu, but can't seem to find this referanced in either SM. Going back to flash F/W (although they are both at the same version.
