Bizhub C353 "Install the imaging unit and close all doors" error
  • bgolpmp
    • Jun 2015
    • 27
    Please help my beloved machine!!!! About 2 weeks ago I replaced the transfer roller in my c353 along with the K imaging unit. After doing that I received an error about the imaging unit not being installed a c2559 I believe. I tried installing the old imaging unit and it gave me the same error. I git busy with work and let it sit for a few weeks and not when I power the unit up it is telling me to "Install the imaging unit and close all doors" and it is telling me to install all 4 units and also I am getting a second message of "Set the toner cartridge and close all doors" and it is also indicating all toners. They are all pretty new. What can be wrong with my machine?????? I need it for work now and I am at a loss. I am sorry if this has been asked before. I looked on google and also this site and came up with nothing.
    Thanks for your time!!
    Andy
  • copyman
    Owner / Technician
    • Sep 2005
    • 4511
    Re: Bizhub C353 "Install the imaging unit and close all doors" error
    Think there was a bulletin about installing all image units. I'll see if I can dig it up. But what is concerning is all the other messages you are getting at same time?
    Did you have any lightning storms?
    You could try initilizing machine in service mode. Keep in mind this will wipe out all your settings.
    • Synthohol
      Certified Konica Expert
      • 5727
      this is info i found based on your symptoms but not all that at once.
      thats crazy!
      maybe one of these will point you in the right direction?
      good luck.
      Related Products:bizhub C203,bizhub C253,bizhub C353
      Related Options:
      Error
      C2559
      Root Cause
      C2559 (C-2559) at power up.
      Workaround/Fix
      CAUSE: The High Voltage Unit has failed.
      SOLUTION: Replace the HV unit (p/n A02E M402 01).
      Problem
      "Set the toner cartridge and close all doors" message that will not clear.
      Solution
      CAUSE: A poor connection at CN25 on the PRCB or CN41 in the harness to CN25.
      SOLUTION: Remove all power from the machine and reseat both connectors.
      After updating firmware, machine indicates the replacement of image units is required.
      Solution
      CAUSE: The DIP switch settings are not staying FIXED.
      SOLUTION: When setting DIPSWs, for DIPSW 51, first set the HEX F0 result and FIX. This will set the correct bits as indicated for the model. Then set DIPSW 55 to the 00001100 as indicated, by setting the HEX 0C result and Fix. The switches will remain set and the display will return to normal.
      • bgolpmp
        • Jun 2015
        • 27
        Thanks for the reply!! I will try these suggestions out tomorrow
        • bgolpmp
          • Jun 2015
          • 27
          Well tomorrow FINALLY came today and I replaced the high voltage board with a new to me one I purchased off of ebay and it is giving me the same issues. I checked the connection on cn25 and that was fine. Where can I go from here??? What are the chances that both boards give me the same error?????
          Thanks for the help!!!!
          Andy
          • allan
            RTFM!!
            • 5459
            Initialize the machine. Worked for me before.
            But before that do an error reset.
            Whatever
            • bgolpmp
              • Jun 2015
              • 27
              no sure what that is but I just did a trouble reset and get the same issues
              • allan
                RTFM!!
                • 5459
                Remove all the units and toners and try an all data clear.
                Had this some years back with IU and toners and that was the only way i got it running again.
                It could be a connection....
                There is an option under initialize to clear system error.
                I don't mean to clear trouble like with a fuser code.
                Remove all the units and toner when you do this.
                Whatever
                • bgolpmp
                  • Jun 2015
                  • 27
                  Thanks for the suggestion but that did not work I really miss and need my printer I might have to go to my backup machine but that one is not color and I like this one better.
                  Any other suggestions? It doesn't even have 300,000 copies on it yet
                  • Synthohol
                    • 5727
                    did you do the 2nd part of my post? bit switches?
                    • bgolpmp
                      • Jun 2015
                      • 27
                      Thanks for the reply. No I did not. I dont know how to do that or where those dip switches are located. I will look in the web tonight along with the manual and try and figure out how to do this
                      • mattcoop11
                        • Jun 2015
                        • 12
                        • bgolpmp
                          • Jun 2015
                          • 27
                          U did rebuild one of the imaging units and when I installed it was when I had this error. I tried the new and old chip and got the same issue. I also installed a new I believe it is called transfer roller in the machine
                          • bgolpmp
                            • Jun 2015
                            • 27
                            Please tell me if I was trying to change the dipsw correctly
                            I pressed stop 00 stop 01 and that brings up a menu
                            I went to system 2
                            Under there was software switch settings
                            in the first box I typed 51
                            In the 2nd box I left alone
                            in the bottom box I changed the first 0 to an f
                            I pressed fix
                            I did the same for 55 except input the correct numbers
                            BUT when I exited out of that screen and went back to the standard screen the error was still there
                            Then I rebooted the printer and the error was still there
                            I also did a trouble reset and the error was still there
                            When I went back into the software switch settings and would type in 51 or 55 in the first box the things I typed into the boxes were not there. It was back to the default I believe 0's
                            Am I doing this wrong?
                            Andy
                            • Synthohol
                              • 5727
                              no, you did it correctly.
                              time for a new machine.
                              In June 2017 that machine was officially discontinued and no longer supported (except supplies).
                              honestly, you can buy a lease return newer machine for the cost of 1 board for that dinosaur.
                              check the 3 gold pins that contact the chip on the IU. maybe one is bent. thats best case scenario.
