KM C360 Yellow Shading on Copies & Prints
  • pick
    • Oct 2015
    • 26
    [Misc] KM C360 Yellow Shading on Copies & Prints
    Hi,
    I have an issue I've never come across before that has me totally stumped. I have a Konica C360 that's giving me very strange yellow shading on both copies and prints, however I cannot replicate this on EVERY copy and print. It's very sporadic. I will attach PDFs of the examples I have. The shading does not seem like a failing DV or Drum, it's very defined and patterned. Thanks in advance. Yellow Shading C360 Scan2.pdfYellow Shading C360 Scan.pdf
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: KM C360 Yellow Shading on Copies & Prints
    Originally posted by pick
    Hi,
    I have an issue I've never come across before that has me totally stumped. I have a Konica C360 that's giving me very strange yellow shading on both copies and prints, however I cannot replicate this on EVERY copy and print. It's very sporadic. I will attach PDFs of the examples I have. The shading does not seem like a failing DV or Drum, it's very defined and patterned. Thanks in advance. [ATTACH]46600[/ATTACH][ATTACH]46599[/ATTACH]
    Do the copy quality adjustments (gradiation) first. And then, even if it doesn't appear to be a drum issue---so easy to swap a color drum on this model. So do that to see if problem moves.
    Possible causes:
    Drum unit issue
    DV unit issue (most likely cause)
    Aftermarket toner
    PH unit (but I doubt it - but check cable and clean it anyway)
    Initialize and run the gradiation adjustments
    • tulintron
      • Jul 2014
      • 665
      I would start by disassembling and cleaning the laser unit. I've seen cases of flat being the problem. Because it is sporadic, it may be some bad contact or dirt in the image formation process.
      As I said above, I would start by disassembling and cleaning the laser.
      • fatduke
        • Jun 2020
        • 75
        Hi!
        What about consumables life?
        Had similar issue with that and after refurbishing DV unit with powder and reset chip I fixed it.
        This is my opinion.
        TY
        • Albonline
          • Sep 2008
          • 1131
          this is digital looking, ram, print head, most likely a loose connection between mpf and print head.
          • tsbservice
            Field tech
            • 7904
            Agree looks like PH unit to me or ribbon cable.
