Konica Minolta C224e - Transfer Roller Unit
  • jbphillips2001
    • Sep 2020
    • 2
    We have a Konica Minolta C224e copier at work that has come to end of life on the Transfer Roller Unit. Can someone tell me exactly where this Transfer Roller unit is? The number of rotations it's displaying is the same number that's on transfer roller belt unit. Is it the same unit that is being sold online as "2nd Image Transfer Roller Assembly" by several vendors? Thank you.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: Konica Minolta C224e - Transfer Roller Unit
    Yes it is the 2nd Image Transfer Roller Assembly. Open the door on the right and look for a long sponge like roller. If you see a green latch with M6 on the label , the roller is part of that same rectangular unit.
    • tsbservice
      Field tech
      • 7906
      If you're unable to even visually locate second transfer roller I'm afraid things can easily go out of control.
      And if counters of ITB unit are also due it's important to replace this unit also and carry out needed adjustments.
      • jbphillips2001
        • Sep 2020
        • 2
        Thank you so much. I'll get it replaced and reset the counter.
        • copier tech
          • 8096
          You don't need to replace this part, simply reset the counter in CE mode.
          However if you do want to place it this is the part number, it simply unclips no tools are required.
          2nd Transfer Roller - A161R71433
          • Synaux
            • Mar 2012
            • 1224
            +1 As long as print quality is acceptable.
            You are obviously an end-user. But if you are feeling adventurous, get yourself a Service Manual and get into "Service Mode" (hopefully it has a default password--do not ask for the password--you will get scolded for asking such things around here) and reset the counter.
            But leave everything else alone!
            FYI, if you are willing to put some work into it, you can remove these rollers and wash the foam roller with soap and water (gently), but be sure to let the roller COMPLETELY dry (rendering the machine worthless for a few days). I would recommend doing this regardless if you order a new roller so you have a spare.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4516
              Just reset the counter in service mode if print quality looks good. No need to replace. Might as well clear the toner filter count while in service mode life counters.
              • Synaux
                • Mar 2012
                • 1224
                I just realized that this end-user will have to reset the counter regardless of replacing the part. dOH!
                jbphillips2001, you will have to figure out how to reset the counter or pay a tech to location to do it for you.
                If you contribute to the site, I will send you the documentation necessary. (but do not go exploring--change the setting and forget you were ever there).
                All that said, a 2nd tranf roller at end of life will not stop the machine from running.
