Upside down on duplex
  • positiveg
    • Jun 2018
    • 299
    C454e
    No matter what settings we change now we get the second size for regular prints or booklets coming out upside down
    Whether we choose long edge or short edge still the same isse.
    It never used to happen now it's just happening
    Any assistance?
    thanks
    • 22920
    Re: Upside down on duplex
    I'm going to guess that somebody changed the default along the way. =^..^=
    • positiveg
      • Jun 2018
      • 299
      But how though?
        • 29330
        To use the booklet setting document must be created as single pages.
        The booklet setting will arrange them in the correct order.
        If you create it as a booklet the booklet setting will screw it it up.
        • Synthohol
          Certified Konica Expert
          • 5734
            • 22801
            be nice if you posted settings for this problem... driver and machine settings
              I'm gonna second this.
              • qbert69
                • Mar 2013
                • 1152
                ALWAYS LET THE MACHINE/DRIVER COMBO PAGINATE FOR YOU!!! You CANNOT design a double page spread and expect it to work correctly!!![emoji57]
                Sent from my SM-N950U1 using Tapatalk
                REACH FOR THE STARS!!!
                Konica Minolta Planetariums!
                • positiveg
                  • Jun 2018
                  • 299
                  Ok I'm printing a simple two page document from PDF.
                  when it flips it comes out upside down,
                  If i choose flip on long side or flip on short side from the PDF print dialog box it still comes out the same way.
                  Same thing happen if we're funning a booklet, (even single pages, as we usually have them single pages then use the booklet setting options and when it flips you'll have like back inside on the front inside and stuff like that.
                  On the C75 using the Fiery we know if we're printing from PDF we choose top bottom, and top top if we're printing from Word, Publisher, InDesign etc.
                    Is the driver or the machine controlling the process?
                    • positiveg
                      • Jun 2018
                      • 299
                      yes it is
                        • 29330
                        Load the pcl6 driver make the setting change in the properties page Not in the PDF dialog box
                        If it still screwed up print pages as PDF and save than print them using the printer dialog box
                        • positiveg
                          • Jun 2018
                          • 299
                          thanks yeah I'll try the PCL 6 version
                          Because now I'm thinking of it I think it started happening after we did some reinstalls after we had a power outage and our servers routers everything got messed up.
                          So I'll give that a shot and let you guys know thanks much.
                          • rrrohan
                            • Sep 2011
                            • 1977
                            lots of customers try to set booklet setting both in driver then in adobe as well and wonder why it comes out wacky
                            • positiveg
                              • Jun 2018
                              • 299
                              I've only really only done it one way from Adobe cause we are aware when yiu do so from inside the pro Tet you get2 up or so on a page and still folded.
                              As someone pointed out that we might need to change the driver that's installed to get this weking good again.
                              Sent from my SM-G955F using Tapatalk
