Reset transfer belt on c454e
  • Leebs14
    • Feb 2014
    • 457
    [Misc] Reset transfer belt on c454e
    Not used to working in these machines but been asked to fit a new transfer belt on one, do I need to clear any counters once fitted or is it automatic?
  • rrrohan
    • Sep 2011
    • 1977
    Re: Reset transfer belt on c454e
    New release it in CE mode with don't door open. Boop the start button. So long as it's blue when you do it close front door. Bob should be ya uncle
    Sent from my Pixel 4 XL using Tapatalk
    • Bix
      • Apr 2018
      • 1421
      The transfer belt does not have a counter chip. Once replaced, you need to reset it from Service Mode. If the annoying problem is "replace the transfer belt", you can simply reset the counter. But be careful, it is highly discouraged because if you have any quality problems in the future, you may not understand why.
      • Leebs14
        • Feb 2014
        • 457
        Thanks worked a treat !
        • rrrohan
          • Sep 2011
          • 1977
          well u have some advise that helped maybe help out the site with a one off donation? https://www.copytechnet.com/forums/v....php?do=donate
          • Leebs14
            • Feb 2014
            • 457
            thank you everyone for your reply, it was the New release machine so opening closing the door worked to reset the counter. One thing though is that the grey's are very pinkish? i have checked the life of everything and all the drums and developer units are well within life, i went into service and did a gradation adjustment but its still the same. Its a chargeable customer so they are wanting it fixed but not sure where I start?
              • 14335
              I would start with cleaning the printhead and IDC sensors, doing and initialize and stabilize and then run gradation again.
              • tsbservice
                Field tech
                • 7904
                +1. Do the basics first.
