Konica Minolta Bizhub C284e Internal error occurred
  • Alex1
    • Oct 2012
    • 285
    I have a Konica Minolta Bizhub C284e with a internal error that occurs, usually in this case i would see a C-2557 or something appears after the reboot. This machine has no errors pop up what so ever and if I go into service mode to see error history its completely blank. Has anyone come across this problem before? Any help would be appreciated.
    • 22917
    Re: Konica Minolta Bizhub C284e Internal error occurred
    C2557 or something?
    It would help to know what the code is. C2557 is black low toner density. =^..^=
    • Alex1
      • Oct 2012
      • 285
      C2557 or something?
      Yes it would definitely help. But there's no code at all. That's what's got me. I've worked on hundreds of these and usually there's a code that appears or has logged in service call history but like I was saying before there's no error code other then internal error the system will reboot and that's it.
      • rrrohan
        • Sep 2011
        • 1977
        so service mode - counter - service call history (data)
        is not showing anything?
        • Alex1
          • Oct 2012
          • 285
          No not showing anything there. That's what's making it harder.
          • copier tech
            • 8095
            Set off a full colour print run or test patterns in service mode, the machine will show 'internal error' & will reboot 3 times.
            Keep running a print run the machine will eventually stop & show the C-2557 etc.
            Maybe your client was turning the machine off/on not waiting for it to reboot & log the code in CE mode.
            • Alex1
              • Oct 2012
              • 285
              The machine rebooted it self 15 times. I will do 50 colour prints or 50 b&w prints either prints will get to 38 pages or 39 pages then stop will a internal error. I stood there while this happened 15 times rebooting it self in hope to see a error come up or something was logged in service mode with no luck. I have never seen this before. I'm baffled.
              • konicavod
                • Feb 2020
                • 27
                take a photo:
                Service Mode -> State confirmation -> Level History 1
                • Alex1
                  • Oct 2012
                  • 285
                  Originally posted by konicavod
                  take a photo:
                  Will do when I head there next
                  • copier tech
                    • 8095
                    TNR levels should be around 6.5% one of them may stand out being too low or high.
                    • Alex1
                      • Oct 2012
                      • 285
                      I'll keep my eye out for it. Its just baffling on on why no error code. Thanks for the post.
                      • copier tech
                        • 8095
                        • Gift
                          • Mar 2011
                          • 2444
                          Have you tried running the machine without a network connection for a while?
                          • rrrohan
                            • Sep 2011
                            • 1977
                            If you temp disable auto internal error reboot on rank C it might display
                            Or print a management list. Might show up on last page of printout (I forget the name but it's different to C code log)
                            • Alex1
                              • Oct 2012
                              • 285
                              Yes that did come to mind same problem unfortunately.
