Konica I Series trouble reset
  • Konicatech
    • Feb 2016
    • 131
    Hi
    Does anyone know the procedure for doing a trouble reset on this series? Its a C250i throwing up a code. Want to see if it will reset.
  • progoffice
    • Nov 2008
    • 333
    Re: Konica I Series trouble reset
    This is from the C650i/C550i/C450i manual, so I would think the steps are the same for the C250i.
    Procedure
    1. Turn OFF the main power switch.
    2. Remove the key cover on the rear side of the control panel, and turn main power switch ON while pressing the Reset key.
    3. Touch [Trouble Reset].
    4. Check to make sure that [OK] is displayed and it has been reset.
    5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
    6. When the machine fails to start even after perform step 1 through 5, turn OFF the main power switch and unplug the power cord.
    7. Insert the power cord after 15 sec. or more, turn ON the main power switch and check if the machine starts correctly.
    • blinxwap
      • Jun 2020
      • 80
      Originally posted by Konicatech
      Hi
      Switch machine off, Remove the cover at the back off the control panel , press the stop button (yellow and red button) at the backhold down and switch on machine , follow normal on screen trouble reset procedure
      Sent from my SM-A505F using Tapatalk
      • tsbservice
        Field tech
        • 7899
        Procedure is the same as previous series just Reset key is a bit hidden. Nothing too fancy. Same applies for doing FW updates just use red(upper) button.
        • khattab.al.masry
          • 212
          I hope the following my intervention to be useful and I have attached the following image to help you where you can find the trouble reset switch.
          How to reset
          Press the Trouble Reset Switch on the Tech. Rep. Setting Switches Board to reset the
          following malfunctions: scanner-related malfunctions, fusing-related malfunctions, exposure
          lamp-related malfunctions and C3FFF.
          For any other malfunctions, open and close the Front Door or turn OFF and ON the power switch.
          • copier tech
            • 8093
            How to reset
            This is the 'i' series model we are discussing here. Not the old C3650 from years ago.
