konica minolta c360i code e 206 and error log problems
  • brent
    • Nov 2008
    • 1208
    I have been scrolling and looking but you guys are way smarter then the internet. lol e 206 and error log problems is what I am having
    with this new bizhub I set up today.. kinda frustrating for sure I can push the button and the log goes away
    but am I looking at a firmware upgrade?
    thanks for all the help as usual
    brent
  • tsbservice
    Field tech
    • 7904
    Re: konica minolta c360i code e 206 and error log problems
    Something like this?
    E206 on setting up a new C3350
    • brent
      • Nov 2008
      • 1208
      well that was awesome I had not seen that toggle before.. these new I series machines have me all goofed up as far as finding anything.. I am hoping that code is history now. as we don't need it.. we just need to copy scan.. thank you I will update if I have an issue with the other log in issue
      thank you for posting the link
      brent
      • copier tech
        • 8095
        brent
        This is a known issue, unsurprisingly the remedy is to update fw.
        Problem
        It has been reported that when installing a new iseries that has arrived with G00-B6 FW C-E206 happens at boot up.
        Key words- e206 ce206 c-e206
        Cause
        Firmware issue
        Workaround
        1. Enter the Utility> Administrator mode
        a. default password is 1234567812345678
        2. Select System Settings
        3. Select Reset Settings
        4. Select System Auto Reset
        5. Turn the Screen Saver Function toggle to Off
        Update the FW to GC2-B6 or later.
        • Walterj
          KONICA MINOLTA
          • Jun 2017
          • 89
          • copier tech
            • 8095
            Click Here To Download - Ricoh, Konica Minolta, Kyocera, Lexmark or Canon Firmware
            • Bix
              • Apr 2018
              • 1421
              brent
              From personal experience, it is due from the marketplace. When you configure the printer and it is not connected to the internet, the marketplace does not configure the screensever correctly and goes into an error state.
