Konica 4752 and C250i printing out gibberish
  • sgporter20
    • Apr 2021
    • 2
    [Misc] Konica 4752 and C250i printing out gibberish
    I have a network with about 50 printing devices that include HP, Xerox, Canon, and these two Konica printer/copiers. The two Konica models print out gibberish from time to time. No other printers do this. I have changed their IP addresses and used two different print servers and the result is always the same. The IPs are not public. It is strange to me that only the Konica printers do this. I am hoping for some advice and possibly a solution to this issue,
    Thank you in advance!
    Steve
    • 22801
    Re: Konica 4752 and C250i printing out gibberish
    Steve
    ASCII code means the wrong print driver is being used.
    what driver are they using?
    • tsbservice
      Field tech
      • 7904
      Check out this setting is on AUTO
      1. Press [Utility]
      2. Press [User settings]
      3. Press [Printer Settings]
      4. Press [Basic Settings]
      5. Press [PDL Settings]
      6. Set to AUTO
      • sgporter20
        • Apr 2021
        • 2
        I am having an issue finding a driver for the C250i. The website does not offer a specific C250i driver. Would I be better off with a common or universal driver?
        If I search the C250i, this is the driver they give me.
        DriverVer=12/02/2019,2.2.2.0
        [Manufacturer]
        %KM%=KONICA MINOLTA,NTamd64,NTamd64.6.0
        [KONICA MINOLTA.NTamd64]
        "KONICA MINOLTA C650iSeriesPCL" = KOAXGJ_G.dll.NTamd64, USBPRINT\KONICA_MINOLTAC650iS2A8C, KONICA_MINOLTAC650iS2A8C
        "KONICA MINOLTA C360iSeriesPCL" = KOAXGJ_G.dll.NTamd64, USBPRINT\KONICA_MINOLTAC360iS2889, KONICA_MINOLTAC360iS2889
        "KONICA MINOLTA C4050iSeriesPCL" = KOAXGJ_G.dll.NTamd64, USBPRINT\KONICA_MINOLTAC4050i3F8B, KONICA_MINOLTAC4050i3F8B
        "KONICA MINOLTA C4000iSeriesPCL" = KOAXGJ_G.dll.NTamd64, USBPRINT\KONICA_MINOLTAC4000i6FB4, KONICA_MINOLTAC4000i6FB4
        "KONICA MINOLTA C3320i PCL" = KOAXGJ_G.dll.NTamd64, USBPRINT\KONICA_MINOLTAC3320iF4EB, KONICA_MINOLTAC3320iF4EB
        "KONICA MINOLTA C750i PCL" = KOAXGJ_G.dll.NTamd64, USBPRINT\KONICA_MINOLTAC750iC104, KONICA_MINOLTAC750iC104
        "KONICA MINOLTA C287iSeriesPCL" = KOAXGJ_G.dll.NTamd64, USBPRINT\KONICA_MINOLTAC287iS6BD5, KONICA_MINOLTAC287iS6BD5
        "KONICA MINOLTA C286iSeriesPCL" = KOAXGJ_G.dll.NTamd64, USBPRINT\KONICA_MINOLTAC286iSA714, KONICA_MINOLTAC286iSA714
        If I search the C250i this is the driver they give me.
          • 22801
          [Manufacturer]
          are you looking on the TECH website?
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            [Manufacturer]
            If you're in the US, try here: KM Drivers
            The latest PCL driver is 2.1.13.0 and is for most of the i series machines. Don't choose Universal, always use PCL or PS instead.
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
            • tsbservice
              Field tech
              • 7904
              +1
              • tsbservice
                Field tech
                • 7904
                Ahhh I will edit my post to +1
                • emujo2
                  • Mar 2017
                  • 1580
                  The C250i is part of a family..You probably need the C300i driver..
                  • srvctec
                    • Oct 2009
                    • 827
                    Huh?
                    The exact same driver file is used for basically all color i series machines. Unless my sarcasm detector (usually spot-on) is defective.
                    • emujo2
                      • Mar 2017
                      • 1580
                      true, but when you install it you must choose the correct family..you would not let the default C750i driver install for the C360i. That is why, after you point the driver install to the INF file you are presented with a list of models to choose from. E
                      • srvctec
                        • Oct 2009
                        • 827
                        Oh, that's right; totally forgot about that.
                        • rolls.bo
                          • Sep 2014
                          • 42
                          I am attaching a file that I made to simplify the installations, since I install MFP every day
                          I hope it can help
                          develop = konicaminolta
                          ineo = bizhub
                          ineo + ..... = bizhub c ....
