KM default Administrator passwords
  • tsbservice
    Field tech
    • 7904
    [Misc] KM default Administrator passwords
    Most here already know them but some are a bit awkward.
    Model Admin Pass PSWC Admin Login/Pass
    20/20p admin/access
    25e (none)
    36/42 12345678 12345678
    40p administrator
    4050/4750 12345678 12345678
    4052/4752 1234567812345678 1234567812345678
    c20 000000 administrator
    c20p administrator
    c25 000000 administrator
    c35 12345678 12345678
    c35p administrator
    C3100p 12345678 12345678
    C3110 12345678 12345678
    c3350/c3850/c3850FS 12345678 12345678
    c3351/c3851/c3851FS 1234567812345678 1234567812345678
    162/163/165/185/210/211/215/226/266/306/225i 000000 sysadm
    c250/c252/c352/c450/c203/c253/c353/c451/c650/c220/c280/c360/c452/c552/c652/c652DS/ 420/500/ 361/421/501/ 223/283/363/423/ 552/652 12345678 12345678
    c224/c224e/c284/c284e/c364/c364e/c454/c454e/c554/c554e/c654/c654e/c754/c754e/654/754/224e/284e/364e/454e/554e/227/287/367/308/308e/368/368e/458/458e/558/558e/658e/758/808/958/C227/C287/C258/C308/C368/C458/C558/C659/C759 1234567812345678 1234567812345678
    C3300i/C4000i/C3320i/C3350i/C4050i/C250i/C300i/C360i/C450i/C550i/C650i/C750i 1234567812345678 1234567812345678
    4000i/5000i/4020i/5020i initpass
    • 22917
    Re: KM default Administrator passwords
    That's really handy tsb. Can I ask a favor? Can you attach it in a text format? It's not so easy to save this in a useable format. =^..^=
    • tsbservice
      Field tech
      • 7904
      Will try later BC. Initially I was going to attach an Excel file with table but my PC do some funny formatting of few cells.
        • 22917
        The forum won't attach an Excel file, but you can attach a zipped file. I've done it a few times. =^..^=
        • mojorolla
          The Wolf
          • 2569
          How about a PDF ?
          Thanks for this tsb, already added to my little black book.
          KM DEFAULT LOGINS.pdf
          • emujo2
            • Mar 2017
            • 1580
            You are incorrect on the 5020I password. E
              • 22917
              How about a PDF ?
              [ATTACH]49265[/ATTACH]
              That works quite nicely. Thank you. =^..^=
              • tsbservice
                Field tech
                • 7904
                How about a PDF ?
                Sigh, being rather busy last days...thanks for that saved me a bit of time
                • tsbservice
                  Field tech
                  • 7904
                  As I installed exactly ZERO bizhub 5020i MFPs but hundreds of it's Brother original MFC-L6900DW you actually may be right as of this moment.
                  For sure it was initpass atleast of the begining of production.
                  See below:
                  Link:
