Develop ineo+227 (Konica ) error code c-2152
  • Aldo-PA3
    • May 2021
    • 3
    227.jpgHi all,
    Currently have error code C-2152 on a Develop ineo+227, have replaced transfer belt, transfer clutch. The machine is now striped down to the frame, i've cleaned all sensors, all motors have been checked, no issues.
    Before i re-assemble, is there anything else i should be looking at? Had this issue numerous times on much older machines like c252, c253 etc. This one has me stumped.
    Any help or advice greatly appreciated.
    Thanks.
  • tulintron
    • Jul 2014
    • 665
    Re: Develop ineo+227 (Konica ) error code c-2152
    How did the error occur?
    Did the printer work and stop?
    Was it after maintenance?
    Is the printer electrically protected?
    Just replaced the belt or ITBU?
    • Aldo-PA3
      • May 2021
      • 3
      The customer logged a call for machine making a loud noise. I found the transfer belt cleaner unit was filled with solidified toner.
      Machine seemed to be running ok, left site, call came back in few days later with the error code attached.
      Replaced full ITBU
      Can confirm the machine is protected yes.
      • tulintron
        • Jul 2014
        • 665
        Between the belt cleaning unit and the waste toner container there is a small plastic piece that makes this connection.
        It may be the cause of toner solidification.
        With the cleaning system locked, noise may have arisen.
        The engine that drives the system may have damaged some icp in the PRCB.
        This reasoning was taken based on your information and replaced parts
        • Aldo-PA3
          • May 2021
          • 3
          That makes sense, is there a way i can determine if it is more PRCB related?
          I'm assuming this will need to be replaced if that is the issue.
          Thanks.
          • tsbservice
            Field tech
            • 7904
            Manual states next items are M3(Fusing motor) and MFPB. I will borrow M3 from another machine to test.
            • Toxic
              • 694
              Check wirings for maybe some pinched wires or damaged insulation.
              • allan
                RTFM!!
                • 5459
                as Per tulintron check the ICP's on PRCB. I would start with the ICP closest to where the clutch plugs in on the board.
                Had this a couple of times on mostly C360 machines.
                Find the IC protector list in manual.
                F13E for CL5 would be suspect here.
                Whatever
