Bizhub C258 code C-2152
  • tsbservice
    Field tech
    • 7909
    Got call for this error C2152: Transfer belt fault at initial position return. Obviously it won't go away upon trouble reset.
    I'm going with another ITB unit and plan to clean inside machine and infamous PS39 sensor. Other than that what may be expected? 1st transfer pressure clutch (CL5) replacement looks like real PITA though.
    As always great Thanks for any tips and tricks from experienced.
  • rrrohan
    • Sep 2011
    • 1977
    Re: Bizhub C258 code C-2152
    U might be lucky and not need to change clutch. Otherwise a 5 min job will turn into a hour
    Sent from my Pixel 4 XL using Tapatalk
      • 22927
      Bizhub C360 w/C2152 error
      bizhub C224 has C2152 error code
      C554e with C2152 error
      There's a photo in this thread from a C284. Not sure if it's any help:
      At one time I loaded a photo from a C654e, ... I cannot seem to find it, but it's PS52 on the C654e. There it is!:
      • tsbservice
        Field tech
        • 7909
        Thanks guys I already dig forum and definitely saw your picture BC. As this is relatively low metered and new machine I don't expect it being dirty but who knows. I have had this once and it was piece of plastic broken from ITB itself. Anyway it's 2+ hours away so basically whole day call and I don't need something stupid which I can miss on my way.
        • tsbservice
          Field tech
          • 7909
          Solved. ITB primary charge roller lever broken - fixed plus PS39 need cleaning.
          • rrrohan
            • Sep 2011
            • 1977
            I didn't thing you could over rotate that gear that drives the colour transfer rollers. Doesn't it just switch between engaged and disengaged. Wonder how it broke
