Konica Minolta C360i - Quality issue
  • Kenny
    • Jun 2009
    • 515
    Hi guys,
    we have a Konica Minolta C360i that was initially having an issue with a yellow background. On site we noticed the yellow TCR was 0.0 so we have checked the developing unit and it seems it has turned black? so we have replaced the yellow drum and developing unit but the issue remains, the yellow TCR goes from 6.6 to 2.4 then back to 6.6 after doing some prints. We have checked the yellow developing unit again and the new one has turned black also.
    on the transfer belt it seems the yellow has covered the belt fully and seem to have taken all the yellow developer out of the developing unit.
    the machine has various P Codes (see attached)​ P CODES.docx Halftones.pdf
    The machines is on the latest firmware and below are the meters
    Total: 35771
    Black: 9146
    Colour: 26625
    we are potentially thinking it is down to the HV BOARD but would like to here some suggestions,
  • Synthohol
    Certified Konica Expert
    • 5734
    id try a toner add until its even with the others then do a background data reset and stabilize and perform all 9 or 12 gradation adjustments.
    could be toner chute is clogged or not replenishing toner.
    not discarding a possible HV issue but check the physical first
    • avecosat
      • Jun 2012
      • 303
      Hello, I had the same problem but I only changed the yellow development unit two months ago and the problem has not returned. As you say, the unit turns black, the value becomes 0 and the unit code appears and constantly resets, but in my case after changing the unit the problem has been resolved.
      • tsbservice
        Field tech
        • 7904
        It can be infamous toner hopper problem. Did you remove and check it?
        What areYellow drum voltages (those are in Table number - Vg and Vdc)?
        • Kenny
          • Jun 2009
          • 515
          yellow drum voltages please(those are in table number - vg and vdc).
          vdc-c 328
          vdc-m 393
          vdc-y 800
          vdc-k 295
          vg-c 368
          vg-m 443
          vg-y 830
          vg-k 365
          • tsbservice
            Field tech
            • 7904
            Originally posted by Kenny
            vdc-c 328
            vdc-m 393
            vdc-y 800
            vdc-k 295
            vg-c 368
            vg-m 443
            vg-y 830
            vg-k 365
            Yellow are way off as IDC judged the image density as low...but first check toner hopper.
            • copier tech
              • 8096
              We have a had a few HV boards fail on the C250i series.
              After you replaced the yellow dev & image units did the device work ok initially ? if yes then you have a toner supply issue.
              If after replacing the yellow IU & dev units the print quality issue was the same immediately after then I would look at replacing the HV board.
              • Kenny
                • Jun 2009
                • 515
                yes the issue was the exact same, we will try your suggestions and update you guys, thank you
                • Andrey51
                  • Feb 2024
                  • 6
                  I had a case when the developer unit did not fill with toner. In my case the sensor in the hopper was dirty and the machine thought that the hopper was full of toner and did not start the tube rotation. Cleaning the sensor helped.
                  • barber782
                    • Aug 2011
                    • 277
                    Are you modifying the black drums to colour drums by any chance?
                    • Kenny
                      • Jun 2009
                      • 515
                      Hi guys,
                      so we have been to site and replaced the HV BOARD and HOPPER unit and a new Y Dev unit but it has once again turned black,
                      the HV board did fix the background issue
                      the hopper unit fixed the TCR issue
                      but pulled the DV unit out and its done the same
                      • Kenny
                        • Jun 2009
                        • 515
                        HI guys,
                        just an update it seems the machine is now up and running,
                        ran 255 full bleed halftones on the yellow and its working again, thank you for your suggestions
