BH 808 finisher jam 72-18
  • splblazer91
    • Jul 2014
    • 204
    FS-536 finisher. It will run 10-15 pages then jam at the finisher entrance rollers. J code 72-18. It never gets past the entrance rollers when it jams. Anyone seen this?
  • Synthohol
    Certified Konica Expert
    • 5731
    Re: BH 808 finisher jam 72-18
    is it getting hung up on a torn black mylar (#4) in the enterance guide?
    • splblazer91
      • Jul 2014
      • 204
      Negative. Only about 400k on this one. I did go ahead and remove that mylar though. That thing is useless.
      • Albonline
        • Sep 2008
        • 1131
        Is the ru unit warped enough yet to separate the conveyance rollers?
        • splblazer91
          • Jul 2014
          • 204
          Havent seen that yet but I did move the finisher to a different machine and it did the same thing.
          Update: I replaced all the metal and plastic entrance guides as well as the Finisher board. Ran 1000 pages and it never jammed.
          • escalante
            • Sep 2018
            • 115
            Good afternoon. I hope the following documentation will help you solve your failure. FS­536_FS­536SD_FS­537_FS537SD, Jam code 72­18, 72­19, 72­21 or 72­22.pdf
            Enviado desde mi Infinix X692 mediante Tapatalk
