Hi,
I work as IT at a small company which uses a bizhub C454e as the in-office copier. Just yesterday the Scan to Email function has stopped sending emails to employee inboxes - the job list says that the scan to email job has completed successfully but no email from the device is coming through to anyone's inbox. Below is the Email RX and TX configuration:
Firmware version: A61F0Y0-F000-G20-K9
Original Email TX (SMTP) Settings for Service Copier Konica Minolta 454e.png
I have tried the following to attempt to fix this issue:
- Set a new self-signed certificate
- Verify machine date/time is correct
- Verify TLS1.2 is enabled
- Changing the POP and SMTP settings to use one of our office's Hosted Exchange emails instead of the AppRiver SMTP relay - when I tried this method the Scan to Email jobs would get stuck on "Sending" in the job list instead of being "Completed" with no email sent.
I've been researching troubleshooting steps and found this forum in the process so I figured I might as well post about the issue see if there are any other suggestions to figure it out. Thanks!
