SOLVED: If you happen to be running an unraid server, note that NETBIOS and SMBv1 are the same thing. You must enabled NETBIOS, or scans to a shared folder will not work. This may be in issue for those on other systems as well, especially any Linux or otherwise *nix-based platform.
Ok, this is weird. My K-M 364e is hardwired to my LAN, and accepts print jobs without issue.
Beginning yesterday, it is suddenly unable to scan to the shared folder on my unraid server. It's been scanning to this folder for a couple years now, and nothing has changed on either the server or copier, to my knowledge. I have done no server updates, beyond regular docker and plugin updates, and I don't think any of those were SMB/sharing related.
I can access the shared folder without problem from my Windows desktop.
I can ping the copier from my desktop, and I can log into the copier's web GUI, so I know it has good connectivity.
I can print to the copier, no problem.
I've tried setting up an FTP destination on the copier, pointing to the same shared folder on the server, but it just says "no specified folder", even though I do have the folder entered into the destination path.
Anyone have any clue what would cause this sort of network blindness? It's so odd to me that it would just suddenly forget how to scan. lol
I've fully rebooted both the server and copier, with no improvement.
Here are the SMB settings. Remember that these were working fine until yesterday:
