C3350i adf problems
  • mrfuser
    • 1594
    C3350i adf problems
    Bizhub c3350i adf is squishing a line on the page when doing more than 1 page through the scanner. Dual scan feeder on this unit .
    See pic for sample. Any ideas?
    This gallery has 1 photos.
  • KMFLT3CH
    • May 2017
    • 205
    Same issue as this thread: https://www.copytechnet.com/forum/te...i-line-on-scan
    I have seen this exact problem myself on a fairly new C4050i machine. Luckily it was still under warranty and tech support had me order the entire ADF to swap, which did fix the problem. Looks like the KB article has you trying a few other things before changing the entire ADF:
    • tsbservice
      Field tech
      • 7906
      Complete POS are those ADFs, had many modifications to the point where it's better get complete new one.
      • Mildred
        Old Technician
        • Aug 2021
        • 4
        Hello Mr Fuser,
        Just something to try, I have had a few re the Grounding spring in the ADF causing the jitter. Please see my attached PDF explaining the fix. Single wire grounding spring going onto the feed roller assembly must sit on top of the little triangle protrusion.
        Hope this helps
        regards Mildred
