Konica Minolta C554e + C658 Driver
  • Kenny
    • Jun 2009
    • 515
    Hi guys,
    does anyone have to correct driver for a TWN4 MultiTech paper cut card reader.
    will need it for a C554e and C658 machine.
    i have tried to use multiple drivers from Dbox but none have worked so far,
    currently getting 'unable to connect to authentication device' error,
    have upgraded C554e to GDL-M1 firmware and is on function version 7
  • Kenny
    • Jun 2009
    • 515
    Re: Konica Minolta C554e + C658 Driver
    does anyone have this?
    • emujo2
      • Mar 2017
      • 1580
      If you can get the hardware IDs you might be able to create one with the LDD tool, but there are no built drivers for this type of card reader..E
      • Synthohol
        Certified Konica Expert
        • 5731
        only 85$ for the compatible reader...
        Amazon.com: RF IDeas PCPROX Plus 82 Series USB Reader RDR-80582AKU : Electronics
        • Kenny
          • Jun 2009
          • 515
          Do you have the LDD tool? had a look on konica but cant find it?
          EDIT ' think ive found it
          • emujo2
            • Mar 2017
            • 1580
            Is the papercut reader a CCID, or keyboard wedge, or both? I don't think you can use the LDD tool for CCID. I would grab the C658 KBW driver and use the tool to build it with the Papercut VID/PID. No idea if this will work. E
