Bizhub c250 not able get into Low Power mode
  • cyta123
    • Aug 2015
    • 46
    I've got a bizhub c250i. When the device should enter the Low Power Mode(eg after 3 min), first screen (after about 2 min) turn into a grey color, and a few seconds later , the control panel restarts . and in next a few seconds machine ready to copy. When I change Lower Power Mode to 10 min, restarts occurs after 9 .min .
    Settings:
    [Power Consumption in Sleep Mode] - High
    [Power Save Settings] - Sleep
    [Enter Power Save Mode] - Normal
    [Power Key Setting] - Power Save
    Nothing has change after update the latest firmware.
  • Ziggy
    • Feb 2018
    • 676
    Settings:
    These machine are designed to wake up when you walk up to it . You can lower the sensitivity in admin mode . I think its at the bottom of the screen where you set it to go to low power.
    • cyta123
      • Aug 2015
      • 46
      it happens automatically, no matter if someone is close the machine
      • kingarthur
        • 1296
        There was a bulletin (which I can't find) for the device coming to life, when no one was around -an earth tag needed to be fitted somewhere on the back of the control panel - maybe someone can supply the bulletin
        • tsbservice
          Field tech
          • 7904
          Screenshot_2024-12-18-18-55-11-166_com.android.chrome.jpg Here we go
          • tsbservice
            Field tech
            • 7904
            Settings:
            Try this to be Disabled.
            Check service history for detailed code errors.
            • cyta123
              • Aug 2015
              • 46
              The problem starts at" Low Power Mode", not Sleep Mode.
              I will try to change a touch panel
