Fiery IC-413 web services access or patch
  • Kanini2k
    • 63
    Just got back with these machines after a long hiatus, my old account Kanini was not accessible anymore so I had to start a new one.
    I work on these Konica Minolta:s more or less as a hobby and now I have a low meter nice C6000L that prints beautifully set up but I have issues with the Fiery IC-413 1.0 RIP.
    I can access through Command Work Station without problem, it prints perfectly and all but I cannot configure the server.
    When clicking "Configure" it says "To configure the Fiery, please enable the web services on the FIery". I have enabled web services and all but I also cannot access the RIP through the IP address with a browser nor can I do the configuration via Command Workstation or on the machine directly.
    I have found one guy who had the same issue 6 years ago on the FIery community but they say you need the patch FIT101171183 installed, which it is not. I can't seem to find this patch anywhere since it is such an old unit. I know it is old and that it would probably be best to update to newer but the machine works great and we only need to do some settings on the server like language etc. Or is it best to just skip the RIP altogether?
    Thanks a lot in advance and this is a great forum for anyone working on newer and older machines!
  • Synthohol
    Certified Konica Expert
    • 5737
    i have 1.0 if you want to re-run system software from scratch however 1.0 runs xp and tls v1.0 and not accessible from browsers anymore unless you use use pale moon browser.
    • Kanini2k
      • 63
      Thank you very much Synthohol, I guessed it was some issues due to the old system (forgot about the TLS issue, have had that issue on some other system as well) and new browsers. I will try the pale moon browser first. The software could be useful if something messes up so if you don't mind I'd be happy to take a backup for future use. The print quality is so great on this C6000, blows away a lot of newer (not KM) units I think and feels sturdy as a tank. ๐Ÿ˜€
      Have a Happy New Year!
      • Synthohol
        • 5737
        sent via PM.
        thanks for being a VIP
        • Kanini2k
          • 63
          Thank you very much for your reply and thanks for the link to the software. I was not able to access through Pale Moon either for some reason, just get the usual "Unable to connect" even when I tried to adjust the TLS settings. I wonder if there's another issue or if it is a firewall issue so I'll try a direct connection with a laptop and a crossover cable as the next step. =)
          • Kanini2k
            • 63
            • Synthohol
              • 5737
              crossover not needed anymore. straight cable works too.
              dont forget to flip both switches if you reinstall system software
              also stop any FTP service running on the PC/laptop. the software makes its own.
              • Kanini2k
                • 63
                Thank you for replying, yes you're right the crossover is not needed anymore. I had no success in using the Pale Moon and I also connected the laptop directly to the RIP in case there was something with the firewall but the same issue persist, I can't access the webpage with entering the IP or configure from Command Workstation but everything else works and it pings correctly etc. I'm stumped and unfortunately you can't do any more settings than I've tried from the machine menu either. If I feel adventurous I will try to reload the software you supplied (yes I knew about the switches but thanks for the reminder =) but I'm a bit vary it will mess things up totally. But then I'll probably have to get another RIP ๐Ÿ˜„ Is there another maybe newer RIP people are switching to on these machines nowadays?
                • Synthohol
                  • 5737
                  The machine and rip are dinosaurs at this point.
                  Best you can do with it is find someone with the windows 7 upgrade version of the ic413. It's a ram and software upgrade along with a bios update so the unit can run windows 7.
                  • Kanini2k
                    • 63
                    Absolutely, I'll have a look around to see if I can get a hold of the upgrades etc., in the meantime the Fiery will run in German language as long as it works and after that we'll see
                    Yes they are dinosaurs but nice onces nevertheless ๐Ÿ˜„
